I am trying to control a device which can get the temperature values ,Because the register address of the values not continuous, so I did not use the Modbus module under EPICS, but used modbus_tk
under python to get the value. In order to match with EPICS, I used the support module PyDevice which is an EPICS device support for Python interpreter, When I run the st.cmd file, the following error occurs, So now there are three files, the db file, the
st.cmd file and the wave.py file that gets the temperature data.
The db files is as flollows:
record(ai, "$(user):GETDATA")
field(DTYP, "pydev")
field(INP,"@temp1.getData()")
field(SCAN, "1 second")
record(waveform, "$(user):TEMP")
field(INP, "@pydev.iointr('temp_sent')")
field(SCAN, "I/O Intr")
#field(INP, "@temp1.temp_array")
field(NELM, "1000")
field(FTVL, "DOUBLE")
The st.cmd files is as follows:
#!../../bin/linux-x86_64/waveioc
< envPaths
epicsEnvSet("EPICS_CA_SERVER_PORT", 5070)
epicsEnvSet("IOCNAME","waveioc")
cd "${TOP}"
dbLoadDatabase "dbd/waveioc.dbd"
waveioc_registerRecordDeviceDriver pdbbase
drvModbusAsynConfigure("WORDIR","CAT1",slaveAddress,modbusFunction,modbusStartAddr,modbusLen,dataType,posMsec,"plcType")
pydev("import sys; sys.path.insert(0,'${PWD}')")
pydev("import modbus_tk")
pydev("from wave import Temp")
pydev("temp1 = Temp('192.168.0.11','502')")
dbLoadRecords "db/dbWaveform.db", "user=${IOCNAME}"
cd "${TOP}/iocBoot/${IOC}"
iocInit
I encounter a problem, the obtained temperature values
are all 0, the real temperature are not 0. If only used modbus_tk without PyDevice, there is no such error, and can caget the real temperature .
caget waveioc:TEMP
waveioc:TEMP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
When the command file runs, it shows:
< envPaths
epicsEnvSet("IOC","waveioc")
epicsEnvSet("TOP","/home/iocusr/xm/waveioc")
epicsEnvSet("MODULES","/opt/epics/base/../modules")
epicsEnvSet("AUTOSAVE","/opt/epics/base/../modules/autosave-R5-7-1")
epicsEnvSet("ASYN","/opt/epics/base/../modules/asyn-R4-41")
epicsEnvSet("BUSY","/opt/epics/base/../modules/busy-1-6-1")
epicsEnvSet("CALC","/opt/epics/base/../modules/calc-R3-7-4")
epicsEnvSet("CAPUTLOG","/opt/epics/base/../modules/caPutLog-3-5")
epicsEnvSet("IOCSTATS","/opt/epics/base/../modules/iocStats-3-1-16")
epicsEnvSet("MODBUS","/opt/epics/base/../modules/modbus-R3-2")
epicsEnvSet("NETDEV","/opt/epics/base/../modules/netDev-1-0-6")
epicsEnvSet("PC-MONITOR","/opt/epics/base/../modules/PC-MONITOR1-0-2")
epicsEnvSet("PROCSERVCONTROL","/opt/epics/base/../modules/procServControl-1-9")
epicsEnvSet("S7NODAVE","/opt/epics/base/../modules/s7nodave-2-1-3")
epicsEnvSet("S7PLC","/opt/epics/base/../modules/s7plc")
epicsEnvSet("SSCAN","/opt/epics/base/../modules/sscan-2-10")
epicsEnvSet("STREAM","/opt/epics/base/../modules/StreamDevice-2-8-9")
epicsEnvSet("SNCSEQ","/opt/epics/base/../modules/seq-2-2-6")
epicsEnvSet("PYDEVICE","/opt/PyDevice")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
cd "/home/iocusr/xm/waveioc"
Executing Python code: import pydev
Executing Python code: import builtins
Executing Python code: builtins.pydev=pydev
Executing Python code: import modbus_tk
Traceback (most recent call last):
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'modbus_tk'
Executing Python code: from wave import Temp
File "/usr/lib/python3.7/wave.py", line 2, in <module>
import modbus_tk
Executing Python code: temp1 = Temp('192.168.0.11','502')
NameError: name 'Temp' is not defined
dbLoadRecords "db/dbWaveform.db", "user=waveioc"
cd "/home/iocusr/xm/waveioc/iocBoot/waveioc"
iocInit
Starting iocInit
## EPICS R7.0.5
## Rev. 2021-09-13T15:44+0800
sevr=info s7plcInit: no stations configured
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
epics>
