1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Substituting every period scan in EPICS MODBUS by I/O Interrupt
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Date: Mon, 25 Jul 2022 21:40:14 +0000
Good evening for all.
I was reading the EPICS MODBUS documentation after realising that i had misspelled a SCAN field in my modbus application and came across the following:
> modbus supports pseudo-interrupt mode on inputs. The poller thread calls device support when there is a new value, so the EPICS records can have >SCAN=I/O Intr and do not need to periodically read the inputs. This is more efficient.
Does this mean that, whatever the modbus device is that i am communicating, i can always substitute my 'field(SCAN, "1 Second")' to 'field(SCAN, "I/O Intr")' and go out unpunished? Will this work against me in the future?
Thanks for any tips.
Marco.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
RE: Substituting every period scan in EPICS MODBUS by I/O Interrupt Mark Rivers via Tech-talk
Prev: Delta Tau issue Mark Rivers via Tech-talk
Next: Re: Delta Tau issue Andy Foster via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Delta Tau issue Lazarski, Krzysztof Z. via Tech-talk
Next: RE: Substituting every period scan in EPICS MODBUS by I/O Interrupt Mark Rivers via Tech-talk
