> I would hope there is some field could be used to define the record as ‘read-only’,
The "rules" in channel access security can include a value from a process variable, so you could define a variable such that when "PV==1" then predesignated records could go to a "read-only" state.
You can also write your own custom records that would have a "read-only" field, if that is what you really want, but for the standard records in EPICS base you would use channel access security.
Ned
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Zhang, Tong via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, August 1, 2022 02:50 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Write permission of a record
I know that channel access security can control the record write permission based on a wide range of rules, but I’m wondering if EPICS has some other way to control the write permission of a record generally from the record definition level? To make it clearer,
I would hope there is some field could be used to define the record as ‘read-only’, that is all external CA put request should be denied, the data only could be updated through the internal device support.
Tong
- Write permission of a record Zhang, Tong via Tech-talk
Re: Write permission of a record Andrew Johnson via Tech-talk
<2022>
<2022>
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
