1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Write permission of a record
From: "Zhang, Tong via Tech-talk" <[email protected]>
Date: Mon, 1 Aug 2022 19:50:47 +0000
I know that channel access security can control the record write permission based on a wide range of rules, but I’m wondering if EPICS has some other way to control the write permission of a record generally from the record definition level? To make it clearer, I would hope there is some field could be used to define the record as ‘read-only’, that is all external CA put request should be denied, the data only could be updated through the internal device support.
Tong
Re: Write permission of a record Arnold, Ned D. via Tech-talk
Re: Write permission of a record Andrew Johnson via Tech-talk
Re: Write permission of a record Kasemir, Kay via Tech-talk
Prev: RE: EPICS Archiver Appliance - Auto-delete Old Data Rebecca Harding - STFC UKRI via Tech-talk
Next: Re: Write permission of a record Arnold, Ned D. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
