1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: streamdevice in command only 2048 length
From: "Zimoch Dirk \(PSI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 2 Aug 2022 13:46:46 +0000
On Tue, 2022-08-02 at 15:41 +0200, Zimoch Dirk wrote:
> On Tue, 2022-08-02 at 18:54 +0800, 孙彬 via Tech-talk wrote:
> > Hi,
> > I use streamdevice ,use udp to read a waveform record,but read bytes only 2048,is there configuration to extend the limit?
> There is no limit in StreamDevice. But I am not do familiar with UDP. I guess there is a limit somewhere. Also maybe in
> asyn?
> Dirk
Typo: But I am not *too* familiar with UDP
Anyway, a quick look in drvAsynIPServerPort.c shows:
#define THEORETICAL_UDP_MAX_SIZE 65507
I do not know where 2048 comes from.
streamdevice in command only 2048 length 孙彬 via Tech-talk
Re: streamdevice in command only 2048 length Zimoch Dirk (PSI) via Tech-talk
Prev: Re: streamdevice in command only 2048 length Zimoch Dirk (PSI) via Tech-talk
Next: Re: streamdevice in command only 2048 length Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
