1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: streamdevice in command only 2048 length
To: "Zimoch Dirk (PSI)" <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 2 Aug 2022 13:50:25 +0000
There is no limit in asyn.
How large is your waveform record?
Please share your startup script, database, and protocol file.
Sent from my iPhone
> On Aug 2, 2022, at 8:42 AM, Zimoch Dirk (PSI) via Tech-talk <[email protected]> wrote:
> On Tue, 2022-08-02 at 18:54 +0800, 孙彬 via Tech-talk wrote:
>> Hi,
>> I use streamdevice ,use udp to read a waveform record,but read bytes only 2048,is there configuration to extend the limit?
> There is no limit in StreamDevice. But I am not do familiar with UDP. I guess there is a limit somewhere. Also maybe in
> asyn?
> Dirk
streamdevice in command only 2048 length 孙彬 via Tech-talk
Re: streamdevice in command only 2048 length Zimoch Dirk (PSI) via Tech-talk
Prev: Re: streamdevice in command only 2048 length Zimoch Dirk (PSI) via Tech-talk
Next: Re: streamdevice in command only 2048 length Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
