1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Industry Pack support for TIP850 under RTEMS
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
To: tech-talk <[email protected]>
Date: Tue, 9 Aug 2022 08:00:54 +0000
Hi everyone,
is someone using (or have ever used) a TIP850 Industry Pack module from TEWS with EPICS?
I have a SBS/GreenSpring VIPC616 VME-card which carries two of such modules. I can compile a RTEMS-IOC with the epics ipac-module running on a MVME2100. The IOC finds the VIPC616 card with the two TIP850 modules:
ipacAddVIPC616(0xD000,0x80000000)
192.168.99.250> ipacReport(2)
  IP Carrier  0: SBS/GreenSpring VIPC616, 4 slots
    C0 S0 : 0xb3/0x09
      ID = 0x9fffd080, I/O = 0x9fffd000
    C0 S1 : 0xb3/0x09
      ID = 0x9fffd180, I/O = 0x9fffd100
    C0 S2 : No IPAC ID
      ID = 0x9fffd280, I/O = 0x9fffd200
    C0 S3 : No IPAC ID
      ID = 0x9fffd380, I/O = 0x9fffd300
Do I need an additional driver for the TIP850 to connect to the I/O-channels?
The epics ipac-module has support for the TIP810 CAN bus interface. Would a TIP850 driver look similar to this one?
Best regards
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8062-15063 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
[email protected]
[email protected]
Re: Industry Pack support for TIP850 under RTEMS Andrew Johnson via Tech-talk
Prev: Re: labCA 3.7.2 building failed Straumann Till via Tech-talk
Next: Re: labCA 3.7.2 building failed Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: labCA 3.7.2 building failed Jong Woo Kim via Tech-talk
Next: Re: Industry Pack support for TIP850 under RTEMS Andrew Johnson via Tech-talk
