1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: labCA 3.7.2 building failed
From: Straumann Till via Tech-talk <[email protected]>
To: Jong Woo Kim <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 9 Aug 2022 08:50:36 +0200
Hello Jong Woo.
Are you sure you have set MATLABDIR in your RELEASE file correctly?
I notice that besides the compiler not finding 'mex.h' the following error is printed:
make[2]: /usr/local/MATLAB/2020b//bin/mexext: Command not found
Here at PSI I define
MATLABDIR = /afs/psi.ch/sys/psi.x86_64_el7/Programming/matlab/2020b/
and experience no errors.
Also:
ls /afs/psi.ch/sys/psi.x86_64_el7/Programming/matlab/2020b/bin/mexext
and
ls /afs/psi.ch/sys/psi.x86_64_el7/Programming/matlab/2020b/extern/include/mex.h
you seem to have a problem either with your MATLABDIR definition or your matlab installation (which includes the possibility that you lack permission to read these files).
HTH
- Till
On 08.08.22 19:56, Jong Woo Kim via Tech-talk wrote:
Hello,
When I built labCA, I encountered an error as below.
version
labca: 3.7.2
matlab: 2020b
I found that mex.h file is in <matlab-top>/extern/include/
Do you have any idea why it says 'No such a file or directory'?
[jkim@localhost labca_3_7_2]$ make
fatal: Not a git repository (or any of the parent directories): .git
make -C ./configure install
make[1]: Entering directory `/usr/local/EPICS_NEW/labca_3_7_2/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
     T_A=linux-x86_64 install
make[2]: Entering directory `/usr/local/EPICS_NEW/labca_3_7_2/configure/O.linux-x86_64'
perl -CSD /usr/local/EPICS_NEW/base-3.15.6/bin/linux-x86_64/convertRelease.pl checkRelease
echo MEXEXT=.mexa64 >>MATLAB_CONFIG_INCLUDE
make[2]: Leaving directory `/usr/local/EPICS_NEW/labca_3_7_2/configure/O.linux-x86_64'
make[1]: Leaving directory `/usr/local/EPICS_NEW/labca_3_7_2/configure'
make -C ./ezca install
make[1]: Entering directory `/usr/local/EPICS_NEW/labca_3_7_2/ezca'
make[2]: Entering directory `/usr/local/EPICS_NEW/labca_3_7_2/ezca/O.linux-x86_64'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/usr/local/EPICS_NEW/labca_3_7_2/ezca/O.linux-x86_64'
make[1]: Leaving directory `/usr/local/EPICS_NEW/labca_3_7_2/ezca'
make -C ./glue install
make[1]: Entering directory `/usr/local/EPICS_NEW/labca_3_7_2/glue'
make[2]: Entering directory `/usr/local/EPICS_NEW/labca_3_7_2/glue/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -DMATLAB_APP   -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/usr/local/EPICS_NEW/base-3.15.6/include/compiler/gcc -I/usr/local/EPICS_NEW/base-3.15.6/include/os/Linux -I/usr/local/EPICS_NEW/base-3.15.6/include           -I../../ezca -I/usr/local/MATLAB/2020b//extern/include    -c ../ini.cc
../ini.cc:7:17: fatal error: mex.h: No such file or directory
  #include <mex.h>
compilation terminated.
make[2]: *** [ini.o] Error 1
make[2]: Leaving directory `/usr/local/EPICS_NEW/labca_3_7_2/glue/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/usr/local/EPICS_NEW/labca_3_7_2/glue'
Best,
Jong Woo
Re: labCA 3.7.2 building failed Jong Woo Kim via Tech-talk
Prev: labCA 3.7.2 building failed Jong Woo Kim via Tech-talk
Next: Industry Pack support for TIP850 under RTEMS Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: labCA 3.7.2 building failed Jong Woo Kim via Tech-talk
