1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Industry Pack support for TIP850 under RTEMS
Cc: "Sintschuk, Michael" <[email protected]>, tech-talk <[email protected]>
Date: Tue, 9 Aug 2022 17:06:10 +0000
The dac128V is a simple DAC driver.
Sent from my iPhone
On Aug 9, 2022, at 12:25 PM, Andrew Johnson via Tech-talk <[email protected]> wrote:
 Hi Michael,
On 8/9/22 3:00 AM, Sintschuk, Michael via Tech-talk wrote:
is someone using (or have ever used) a TIP850 Industry Pack module from TEWS with EPICS?
I have a SBS/GreenSpring VIPC616 VME-card which carries two of such modules. I can compile a RTEMS-IOC with the epics ipac-module running on a MVME2100. The IOC finds the VIPC616 card with the two TIP850 modules:
ipacAddVIPC616(0xD000,0x80000000)
192.168.99.250> ipacReport(2)
  IP Carrier  0: SBS/GreenSpring VIPC616, 4 slots
    C0 S0 : 0xb3/0x09
      ID = 0x9fffd080, I/O = 0x9fffd000
    C0 S1 : 0xb3/0x09
      ID = 0x9fffd180, I/O = 0x9fffd100
    C0 S2 : No IPAC ID
      ID = 0x9fffd280, I/O = 0x9fffd200
    C0 S3 : No IPAC ID
      ID = 0x9fffd380, I/O = 0x9fffd300
Do I need an additional driver for the TIP850 to connect to the I/O-channels?
The epics ipac-module has support for the TIP810 CAN bus interface. Would a TIP850 driver look similar to this one?
Yes you will need a separate EPICS IPAC Module driver to actually perform I/O through the hardware. The TIP850 provides 12-bit ADC & DAC channels, it will be different (and probably simpler) than the TIP810 CANbus driver that's included in drvIpac itself. Drivers based on the epics devLib API can be built for both RTEMS and VxWorks (and even Linux).
Unfortunately I can't find any other EPICS Industry Pack drivers for modules that have both an ADC and DAC on them, the synApps ip330 support module for the Acromag IP330 ADC board looks to be a bit more complex than you might need for doing simple analogue I/O. There are EPICS drivers available online for IPAC digital I/O modules, the synApps ipUnidig module is a more straightforward example, but it implements a different set of Asyn interfaces than you need for the ADC and DAC on the TIP850.
Can anyone suggest a good starting point for writing a driver for a ADC/DAC IPAC module?
- Andrew
Complexity comes for free, Simplicity you have to work for.
AW: Industry Pack support for TIP850 under RTEMS Sintschuk, Michael via Tech-talk
Re: Industry Pack support for TIP850 under RTEMS Andrew Johnson via Tech-talk
Prev: Re: Industry Pack support for TIP850 under RTEMS Andrew Johnson via Tech-talk
Next: Makefile rule differences with base 3.14 vs 3.15+ in ADCore build with pvi Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: AW: Industry Pack support for TIP850 under RTEMS Sintschuk, Michael via Tech-talk
