1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: ai - record unfortunately does not behave as I expect it to
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 11 Aug 2022 17:09:22 +0200
The plain "Soft Channel" Device Support does not convert - you would have to write into VAL.
To use RVAL you need to...
  • use the "Raw Soft Channel" Device Support that converts
  • set the LINR field to select the type of conversion you want. (Probably "SLOPE" in your case.)
Also, CP in an OUT link does not make sense - you need PP to trigger the target.
Cheers,
~Ralph
On Thu, 11 Aug 2022 at 17:01, Heinz Junkes via Tech-talk <[email protected]> wrote:
I probably didn't take something into account, but unfortunately I don't see what I did wrong.
I have modified the ai- record from dbExample1.db:
record(ai, "$(user):aiExample")
        field(DESC, "Analog input")
#       field(INP, "$(user):calcExample.VAL  NPP NMS")
        field(ASLO, "2")
        field(EGU, "Counts")
        field(HOPR, "20")
        field(LOPR, "0")
        field(HIHI, "16")
        field(HIGH, "6")
        field(LOW, "4")
        field(LOLO, "2")
        field(HHSV, "MAJOR")
        field(HSV, "MINOR")
        field(LSV, "MINOR")
        field(LLSV, "MAJOR")
and write into this record (RVAL) with a calcout record:
record(calcout, "$(user):dummOut") {
  field(INPA, "$(user):calcExample.VAL MS CP")
  field(CALC, "A")
  field(OUT , "$(user):aiExample.RVAL CP")
RVAL is also changed, but VAL remains 0:
(base) hactar:iocmyExample junkes$ camonitor junkes:aiExample.RVAL junkes:aiExample.VAL junkes:aiExample.ASLO
junkes:aiExample.RVAL          2022-08-11 16:52:57.014817 2 LOLO MAJOR
junkes:aiExample.VAL           2022-08-11 16:52:57.014817 0 LOLO MAJOR
junkes:aiExample.ASLO          2022-08-11 16:52:57.014817 2 LOLO MAJOR
junkes:aiExample.RVAL          2022-08-11 16:52:58.016001 3 LOLO MAJOR
junkes:aiExample.RVAL          2022-08-11 16:52:59.017708 4 LOLO MAJOR
junkes:aiExample.RVAL          2022-08-11 16:53:00.015190 5 LOLO MAJOR
junkes:aiExample.RVAL          2022-08-11 16:53:01.017940 6 LOLO MAJOR
junkes:aiExample.RVAL          2022-08-11 16:53:02.015414 7 LOLO MAJOR
junkes:aiExample.RVAL          2022-08-11 16:53:03.018187 8 LOLO MAJOR
junkes:aiExample.RVAL          2022-08-11 16:53:04.018058 9 LOLO MAJOR
In the record reference manual :
If the device support sets the RVAL field, the LINR field controls how this gets converted into engineering units and placed in the VAL field as follows:
1. RVAL is converted to a double and ROFF is added to it.
2. If ASLO is non-zero the value is multiplied by ASLO.
3. AOFF is added.
Danke,  for taking a look,
Heinz
Re: ai - record unfortunately does not behave as I expect it to Heinz Junkes via Tech-talk
Prev: ai - record unfortunately does not behave as I expect it to Heinz Junkes via Tech-talk
Next: Re: ai - record unfortunately does not behave as I expect it to Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: ai - record unfortunately does not behave as I expect it to Heinz Junkes via Tech-talk
