Hi all, I met a question. I use EPICS 3.15.8 ,linux os. I want to use a driver in github https://github.com/iattarla/StepmotorEpics. But failed.Here is the output of st.cmd. I have no idea about it. ********************************************************************** [linxs@rhel8 iocstepmotor]$ ../../bin/linux-x86_64/stepmotor st.cmd.serial #!../../bin/linux-x86_64/stepmotor ## You may have to change stepmotor to something else ## everywhere it appears in this file < envPaths epicsEnvSet("IOC","iocstepmotor") epicsEnvSet("TOP","/home/linxs/Desktop/yy/StepmotorEpics-develop") epicsEnvSet("EPICS_BASE","/usr/local/EPICS/base-3.15.8") epicsEnvSet("SNCSEQ","/usr/local/EPICS/extensions/src/seq") epicsEnvSet("ASYN","/usr/local/EPICS/extensions/src/asyn") epicsEnvSet("STREAM","/usr/local/EPICS/extensions/src/streamdevice") epicsEnvSet("CALC","/usr/local/EPICS/extensions/src/calc") epicsEnvSet("STREAM_PROTOCOL_PATH", "/home/linxs/Desktop/yy/StepmotorEpics-develop/protocols/") cd /home/linxs/Desktop/yy/StepmotorEpics-develop ## Register all support components dbLoadDatabase "dbd/stepmotor.dbd" Declaration of recordtype(scalcout) preceeded full definition. Error at or before "}" in file "dbd/stepmotor.dbd" line 5567 stepmotor_registerRecordDeviceDriver pdbbase registerRecordDeviceDriver failed aSub registerRecordDeviceDriver failed aai registerRecordDeviceDriver failed aao registerRecordDeviceDriver failed ai registerRecordDeviceDriver failed ao registerRecordDeviceDriver failed bi registerRecordDeviceDriver failed bo registerRecordDeviceDriver failed calcout registerRecordDeviceDriver failed dfanout registerRecordDeviceDriver failed event registerRecordDeviceDriver failed fanout registerRecordDeviceDriver failed histogram registerRecordDeviceDriver failed lso registerRecordDeviceDriver failed mbbi registerRecordDeviceDriver failed mbbiDirect registerRecordDeviceDriver failed mbboDirect registerRecordDeviceDriver failed permissive registerRecordDeviceDriver failed printf registerRecordDeviceDriver failed sel registerRecordDeviceDriver failed state registerRecordDeviceDriver failed sub registerRecordDeviceDriver failed subArray ## Load record instances #dbLoadRecords("db/xxx.db","user=bpmHost") dbLoadRecords("db/stepmotor.db") Record "motor_no" is of unknown type "ai" Error at or before ")" in file "db/stepmotor.db" line 6 Error: syntax error dbLoadRecords: failed to load db/stepmotor.db drvAsynSerialPortConfigure("ipconn","/dev/ttyACM0",0,0,0) asynSetOption("ipconn",-1,'baud',"115200") asynSetOption("ipconn",-1,"bits","8") asynSetOption("ipconn",-1,"parity","none") asynSetOption("ipconn",-1,"stop","1") asynSetTraceMask("ipconn",-1,0x9) asynSetTraceIOMask("ipconn",-1,0x2) cd /home/linxs/Desktop/yy/StepmotorEpics-develop/iocBoot/iocstepmotor iocInit Starting iocInit ############################################################################ ## EPICS R3.15.8 ## EPICS Base built Nov 4 2021 ############################################################################ iocRun: All initialization complete ## Start any sequence programs #seq sncxxx,"user=bpmHost" epics> dbl epics> *********************************************************** I doubt: a) I use epics 3.15.8,but the use 3.14 or 3.13 ,does it matter? b) why so many registerRecordDeviceDriver failed error. Any suggestion was appreciate. Regards, Liang
ANJ, 14 Sep 2022 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
