1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: PVs in galil-3-6
To: "[email protected]" <[email protected]>, Mark <[email protected]>
Date: Mon, 5 Sep 2022 13:11:29 +0000
Hi Mark,
I helped Jong Woo with a couple of issues, and in a couple of days he had it working.  The main problems were that he needed to enable the amplifier in the medm screen, and he had mistakenly configured the axis to use digital inputs to disable it.
From: Tech-talk <[email protected]> on behalf of Mark via Tech-talk <[email protected]>
Sent: Monday, September 5, 2022 8:02 AM
To: [email protected] <[email protected]>
Hi Jong Woo,
Apologies, there is no documentation describing the PV list with Galil EPICS driver.
If the motor is still not working, could you please tell me about your motor setup?
Do you have a stepper with no encoder, a brushed servo or brushless servo?
In the meantime, to run basic motor controls the following databases are needed:
galil_motors-v6-10up.substitutions (motor records for motor control)
galil_dmc_ctrl.substitutions (Controller wide settings)
galil_motor_extras.substitutions (settings outside the motor record eg. motor type)
Once those databases are loaded, after attempting to move the motor, inspect the PV
DMC01:ERROR_MON for error messages, it may give some clues.  If no message is displayed the problem is likely
to be basic setup items such as; motor tuning, commutation, etc.
The motor record fields are desribed at the link below:
https://epics.anl.gov/bcda/synApps/motor/motorRecord.html
Kind regards,
Mark Clift
 width= Virus-free.www.avg.com
Re: PVs in galil-3-6 Mark via Tech-talk
Prev: Re: PVs in galil-3-6 Mark via Tech-talk
Next: 'CAS-client' failed in ../db/dbEvent.c line 540 Makarov, Oleg A. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Stream error when drive motro 网易邮件中心 via Tech-talk
