Hi Jong Woo, Apologies, there is no documentation describing the PV list with Galil EPICS driver. If the motor is still not working, could you please tell me about your motor setup? Do you have a stepper with no encoder, a brushed servo or brushless servo? In the meantime, to run basic motor controls the following databases are needed: galil_motors-v6-10up.substitutions (motor records for motor control) galil_dmc_ctrl.substitutions (Controller wide settings) galil_motor_extras.substitutions (settings outside the motor record eg. motor type) Once those databases are loaded, after attempting to move the motor, inspect the PV DMC01:ERROR_MON for error messages, it may give some clues. If no message is displayed the problem is likely to be basic setup items such as; motor tuning, commutation, etc. The motor record fields are desribed at the link below: https://epics.anl.gov/bcda/synApps/motor/motorRecord.html Kind regards, Mark Clift
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
