1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: areaDetector synchronization question
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 17 Aug 2022 14:58:01 +0200
On Wed, 17 Aug 2022 at 14:46, Jörn Dreyer via Tech-talk <[email protected]> wrote:
If I read the unique id from both plugins and make sure the are the same, how
big is the chance that the data does not match if I read them in two threads
(thread 1: the  image, thread 2: the stats information)?
Would the situation improve if I can remove the gateway process?
The one thing that would remove the issue:
Use pvAccess, where the stats and the image are part of the same structure, and the client is guaranteed to get consistent updates.
If you are exporting into a different protocol anyway, the difference shouldn't be that much. In terms of being future-proof, it would be a big step forward.
Cheers,
~Ralph
Re: areaDetector synchronization question Shen, Guobao via Tech-talk
Re: areaDetector synchronization question Mark Rivers via Tech-talk
areaDetector synchronization question Jörn Dreyer via Tech-talk
Prev: areaDetector synchronization question Jörn Dreyer via Tech-talk
Next: Re: areaDetector synchronization question Shen, Guobao via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
