Hi Folks,
I want to read data from an EPICS control system into another control system.
The setup that I have is as follows:
A Basler camera with 659x495 pixels read out by ADAravis/ADGenICam.
Attached to the driver is a NDStdArraysPlugin and an NDStatsPlugin.
The data will be accesed via an epics gateway process that runs on a gateway
server connecting the local Epics network to the global experiment network
using channel access
I want to read the ArrayData from the NDStdArrayPlugin and the Centroid and
Profile information from the NDStatsPlugin at a rate of 10Hz.
If I read the unique id from both plugins and make sure the are the same, how
big is the chance that the data does not match if I read them in two threads
(thread 1: the image, thread 2: the stats information)?
Would the situation improve if I can remove the gateway process?
Jörn
- Re: areaDetector synchronization question Ralph Lange via Tech-talk
Re: RTEMS 5 Cannot Read Event Generator Pietryla, Tony via Tech-talk
<2022>
Re: Re: Re: Re: Re: RTEMS 5 Cannot Read Event Generator chengsn via Tech-talk
<2022>
