1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: EPICS for a small lab - overkill?
From: Sean Leavey - STFC UKRI via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Thu, 18 Aug 2022 19:09:16 +0000
Hi Michael,
> fyi.  Archiver Appliance can be scaled down.  I have AA
> running on a raspberry pi 3 in my apartment recording ~10 PVs.
Good to know it can work on that scale!
>> wrt. "I could probably write one in 20 lines of ..."
> I'm sure you could, and many have.  As with most software,
> getting a 90% solution is easy.  The trouble is that last
> 10% consists of things which aren't apparent.  eg. recording
> disconnect/reconnect, data type change, and various problems
> with timestamps.  Events which can, and imo. eventually will,
> turn up in every installation no matter the size.
Indeed, I guess I was hoping someone else had already done what you say, started with 20 lines of Python and fixed the edge cases you mention, without it becoming a behemoth. But you've convinced me to give Archiver Appliance a go with what you said about the Pis!
Cheers,
Sean
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: EPICS for a small lab - overkill? Pete Jemian via Tech-talk
EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Re: EPICS for a small lab - overkill? Arnold, Ned D. via Tech-talk
Re: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
Re: EPICS for a small lab - overkill? Michael Davidsaver via Tech-talk
Prev: Re: EPICS for a small lab - overkill? Michael Davidsaver via Tech-talk
Next: Re: EPICS for a small lab - overkill? Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: EPICS for a small lab - overkill? Maren Purves via Tech-talk
Next: Re: EPICS for a small lab - overkill? Pete Jemian via Tech-talk
