On 8/17/22 12:47, Sean Leavey - STFC UKRI via Tech-talk wrote:
Sounds reasonable to me!
Great. Do you have any recommendations on how the single box should be set up? I saw some Docker images but not sure it's worth the effort over just building from source manually. I'd probably opt for Debian because that's what I know best. I'd put the IOC on the same box as the base, and use the Modbus support that I think is baked in already.
Archival is something I wanted to ask more about. It doesn't look like a good idea to use Archiver Appliance. Is there a lightweight archiver for a handful of channels (say up to 20) at 1 Hz or less? I could probably write one in 20 lines of Python (camonitor some channels, write values to a text file every N seconds, rotate file once per day), but I hope there's one that also supports data access, e.g. retrieving data between certain times via some network request... wishful thinking?
fyi. Archiver Appliance can be scaled down. I have AA
running on a raspberry pi 3 in my apartment recording ~10 PVs.
The only adjustment I have to make made for this little rpi
is to reduce the JVM memory limit ("-Xmx128M"). Which works
just fine for such a small setup.
wrt. "I could probably write one in 20 lines of ..."
I'm sure you could, and many have. As with most software,
getting a 90% solution is easy. The trouble is that last
10% consists of things which aren't apparent. eg. recording
disconnect/reconnect, data type change, and various problems
with timestamps. Events which can, and imo. eventually will,
turn up in every installation no matter the size.
While there were, and are, a number of special purpose,
and/or site specific archivers. AA is one of a small
number (I think 3) which are flexible and robust enough to
gain widespread adoption. Of these, AA is the only one
currently recommended by its author for new installs.
Sent: 17 August 2022 20:41
To: [email protected]; Leavey, Sean (STFC,ROE,UKATC)
Subject: Re: EPICS for a small lab - overkill?
Has anyone used EPICS on such a small scale? Was it more trouble than it was worth compared to turnkey commercial solutions?
We use it in the labs and for small test stands all the time ... and those are much easier to manage than the large deployments ... you don't have to manage 100's of IOCs, hundreds of thousands of process variables, data archiving does not require a large "archiver" etc, etc, etc. The size of the system greatly increases the maintenance overhead.
It also sounds like your I/O could be accomplished with Ethernet-based I/O with the IOC running whereever convenient.
Ned
From: Tech-talk <[email protected]> on behalf of Sean Leavey - STFC UKRI via Tech-talk <[email protected]>
Sent: Wednesday, August 17, 2022 02:26 PM
To: [email protected] <[email protected]>
Subject: EPICS for a small lab - overkill?
Hi all,
I'm trying to determine the feasibility of using EPICS for simple monitoring of a small clean room facility. We'll need to read out various sensors (particle counters, temperature, etc.) via Modbus over Ethernet and archive the data at low speed (a few times per minute maybe) and also ideally display live data to lab users on a GUI (e.g. MEDM or modern equivalents). We're probably going to have a small number of outputs as well: automated switching of lights, fans, motors, that kind of thing. Maybe some alarms for e.g. triggering a warning light if particle counts get too high. No closed loops.
We could probably just use LabVIEW or similar but I don't like it much and prefer a licence-free and open source solution that can be easily adapted as needed. Plus, I may clone the EPICS setup to a different lab in a different city that we work with, so it would be nice to be able to use a gateway to access and archive their channels as well.
Any input would be appreciated!
Sean Leavey
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
- RE: EPICS for a small lab - overkill? Feister, Scott via Tech-talk
- Re: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
- EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
- Re: EPICS for a small lab - overkill? Arnold, Ned D. via Tech-talk
Re: Re: RTEMS 5 Cannot Read Event Generator Hamadyk, Paul (DLSLtd, RAL, LSCI) via Tech-talk
<2022>
2025
2026
RE: EPICS for a small lab - overkill? Sean Leavey - STFC UKRI via Tech-talk
<2022>
2025
2026
