1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: SHRLIB_VESION Variable
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Sun, 28 Aug 2022 07:20:51 +0000
Hi
How much is it important to set the SHRLIB_VERSION when building support modules? I know it is set by default to the base version when building EPICS base but it seems it is optional when building any support modules. I did this test in our RPM setup, I had all support modules built using asyn 4.41 and I deployed an RPM for asyn 4.42, doing “yum install stream-device” failed because it explicitly asked for asyn 4.41 “libasyn.so.4.41”. I unset the variable in the base and removed it in the support modules, it did update asyn and installed any module that uses asyn, but I am wondering how much this would affect compatibility and dependencies between modules.
Abdalla
Re: SHRLIB_VESION Variable Andrew Johnson via Tech-talk
Re: SHRLIB_VESION Variable Michael Davidsaver via Tech-talk
Prev: RE: setInteger64Param Mark Rivers via Tech-talk
Next: Re: Eurotherm modbus support William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Eurotherm modbus support William Kirstaedter via Tech-talk
Next: Re: SHRLIB_VESION Variable Andrew Johnson via Tech-talk
