1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Eurotherm modbus support
From: William Kirstaedter via Tech-talk <[email protected]>
To: "Wlodek, Jakub" <[email protected]>, Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 29 Aug 2022 11:55:35 +0200
thanks for fixing the support module,
now I can compile it.
but I struggle to get the example app compiled...
epics@priscilla:~/EPICS/epics-support/eurotherm2k/iocs/example_modbus$ make
make -C ./configure install
make[1]: Entering directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/configure/O.linux-x86_64'
perl -CSD /home/epics/EPICS/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/configure/O.linux-x86_64'
make[1]: Leaving directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/configure'
make -C example_modbusApp/Db install
make[1]: Entering directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/example_modbusApp/Db'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[2]: Entering directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/example_modbusApp/Db/O.linux-x86_64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/example_modbusApp/Db/O.linux-x86_64'
make[1]: Leaving directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/example_modbusApp/Db'
make -C example_modbusApp/src install
make[1]: Entering directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/example_modbusApp/src'
make[2]: Entering directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/example_modbusApp/src/O.linux-x86_64'
Creating dbd file example_modbus.dbd
perl -CSD /home/epics/EPICS/epics-base/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/home/epics/EPICS/epics-support/calc/dbd -I/home/epics/EPICS/epics-support/asyn/dbd -I/home/epics/EPICS/epics-support/eurotherm2k/dbd -I/home/epics/EPICS/epics-support/modbus/dbd -I/home/epics/EPICS/epics-base/dbd -o example_modbus.dbd base.dbd asyn.dbd drvAsynIPPort.dbd drvAsynSerialPort.dbd modbusApp.dbd modbusSupport.dbd eurothermModbusSupport.dbd
perl -CSD /home/epics/EPICS/epics-base/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../dbd -I/home/epics/EPICS/epics-support/calc/dbd -I/home/epics/EPICS/epics-support/asyn/dbd -I/home/epics/EPICS/epics-support/eurotherm2k/dbd -I/home/epics/EPICS/epics-support/modbus/dbd -I/home/epics/EPICS/epics-base/dbd    -o example_modbus_registerRecordDeviceDriver.cpp ../O.Common/example_modbus.dbd example_modbus_registerRecordDeviceDriver /home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics/EPICS/epics-support/calc/include   -I/home/epics/EPICS/epics-support/asyn/include      -I/home/epics/EPICS/epics-support/modbus/include -I/home/epics/EPICS/epics-base/include/compiler/gcc -I/home/epics/EPICS/epics-base/include/os/Linux -I/home/epics/EPICS/epics-base/include        -MM -MF example_modbus_registerRecordDeviceDriver.d  example_modbus_registerRecordDeviceDriver.cpp
Installing created dbd file ../../../dbd/example_modbus.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/epics/EPICS/epics-support/calc/include   -I/home/epics/EPICS/epics-support/asyn/include      -I/home/epics/EPICS/epics-support/modbus/include -I/home/epics/EPICS/epics-base/include/compiler/gcc -I/home/epics/EPICS/epics-base/include/os/Linux -I/home/epics/EPICS/epics-base/include        -c example_modbus_registerRecordDeviceDriver.cpp
/usr/bin/g++ -o example_modbus  -L/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/lib/linux-x86_64 -L/home/epics/EPICS/base-7.0/lib/linux-x86_64 -L/home/epics/EPICS/epics-support/asyn/lib/linux-x86_64 -L/home/epics/EPICS/epics-support/eurotherm2k/lib/linux-x86_64 -L/home/epics/EPICS/epics-support/modbus/lib/linux-x86_64 -Wl,-rpath,/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/lib/linux-x86_64 -Wl,-rpath,/home/epics/EPICS/base-7.0/lib/linux-x86_64 -Wl,-rpath,/home/epics/EPICS/epics-support/asyn/lib/linux-x86_64 -Wl,-rpath,/home/epics/EPICS/epics-support/eurotherm2k/lib/linux-x86_64 -Wl,-rpath,/home/epics/EPICS/epics-support/modbus/lib/linux-x86_64           -rdynamic -m64         example_modbus_registerRecordDeviceDriver.o example_modbusMain.o    -leurothermModbus -lmodbus -lasyn -ldbRecStd -ldbCore -lca -lCom
/usr/bin/ld: /home/epics/EPICS/epics-support/eurotherm2k/lib/linux-x86_64/libeurothermModbus.so: undefined reference to `drvModbusAsynConfigure(char const*, char const*, int, int, int, int, char const*, int, char const*)'
collect2: error: ld returned 1 exit status
make[2]: *** [/home/epics/EPICS/epics-base/configure/RULES_BUILD:231: example_modbus] Error 1
make[2]: Leaving directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/example_modbusApp/src/O.linux-x86_64'
make[1]: *** [/home/epics/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/epics/EPICS/epics-support/eurotherm2k/iocs/example_modbus/example_modbusApp/src'
make: *** [/home/epics/EPICS/epics-base/configure/RULES_DIRS:85: example_modbusApp/src.install] Error 2
what should I include in the Makefile to get it to run?
thanks,
William Kirstaedter
PP&B Computer Support Group
Fritz-Haber-Institut Berlin
Am 26.08.22 um 19:07 schrieb Wlodek, Jakub:
I have applied and pushed the patch, and can now build OK with modbus R3-2:
[jwlodek@dell-rhel8 eurotherm2k]$ make clean uninstall -s
[jwlodek@dell-rhel8 eurotherm2k]$ make -sj
[jwlodek@dell-rhel8 eurotherm2k]$ more /usr/lib/epics/README | grep MODBUS
MODBUS          - R3-2
-Jakub
Sent: Friday, August 26, 2022 12:54 PM
To: Wlodek, Jakub <[email protected]>; William Kirstaedter <[email protected]>; [email protected] <[email protected]>
Subject: RE: Eurotherm modbus support
Hi Jakub ,
Ø  I was planning on getting it working with the newer modbus version at some point, which it seems you have already done, perhaps we should just apply those changes to the repo?
That sounds good.  Are you OK with just applying my changes using the “patch” command, or do you want me to fork the repository and make a PR?
One thing you need to do before applying the patch is to do:
git mv eurothermModbus.c eurothermModbus.cpp
Sent: Friday, August 26, 2022 11:50 AM
To: Mark Rivers <[email protected]>; William Kirstaedter <[email protected]>; [email protected]
Hi Mark,
This repo is a backup of an IOC instance we had running that as far as I could tell had no upstream master (I believe it was downloaded as a source tarball, probably from the DLS site). I was planning on getting it working with the newer modbus version at some point, which it seems you have already done, perhaps we should just apply those changes to the repo?
Best,
Jakub
Sent: Friday, August 26, 2022 12:24 PM
To: William Kirstaedter <[email protected]>; [email protected] <[email protected]>; Wlodek, Jakub <[email protected]>
I now realize that DLS repository is not the same as the one you are using.  However, this one does seem to be the same:
https://github.com/jwlodek/eurotherm2k
Jakub, is this repository a fork of a master somewhere else, or is this now the primary repository?
Sent: Friday, August 26, 2022 11:08 AM
Hi William,
It appears that the eurothemModbus source code is on Github here:
https://github.com/dls-controls/eurothermModbus
Does your gitlab dump differ from that?
Sent: Friday, August 26, 2022 8:41 AM
To: Mark Rivers <[email protected]>; [email protected]
Hi Mark,
unfortunately, it doesnt work, various casts fail.
I've saved a dump here: https://gitlab.fhi.mpg.de/kw/eurotherm2k
(should be externally accessible)
William Kirstaedter
Am 26.08.22 um 14:40 schrieb Mark Rivers:
Hi William,
You can probably just rename eurothermModbus.c to eurothermModbus.cpp.  See if that works.
How does eurothermModbus use drvModbusAsyn?
From: Tech-talk on behalf of William Kirstaedter via Tech-talk
Sent: Friday, August 26, 2022 7:20 AM
To: [email protected]
Subject: Eurotherm modbus support
unfortunately the DLS site for the eurotherm support module is not available anymore...
(http://controls.diamond.ac.uk/downloads/support/eurotherm2k/)
does anybody still maintain eurotherms?
I kinda converted the 1-22 release to work with my environment and am now running into a C / C++ error...
newer asyn versions reference vector.h which is C++ while my eurotherm support file is C, which is bad because the C compiler doesnt know about the C++ vector.h ...
In file included from /home/epics/EPICS/epics-support/modbus/include/drvModbusAsyn.h:15,
                 from ../eurothermModbus.c:25:
/home/epics/EPICS/epics-support/asyn/include/asynPortDriver.h:4:10: fatal error: vector: No such file or directory
 #include <vector>
compilation terminated.
Im not sure how to get around this....
maybe someone with more experience in the EPICS build system can help me out.
thanks,
William
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail: [email protected]
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
Re: Eurotherm modbus support Mark Rivers via Tech-talk
Re: Eurotherm modbus support William Kirstaedter via Tech-talk
RE: Eurotherm modbus support Mark Rivers via Tech-talk
Re: Eurotherm modbus support Wlodek, Jakub via Tech-talk
Prev: SHRLIB_VESION Variable Abdalla Ahmad via Tech-talk
Next: Re: Eurotherm modbus support Wlodek, Jakub via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Eurotherm modbus support Wlodek, Jakub via Tech-talk
