1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: EPICS on ESP32
From: "Davis, Mark via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Florian Feldbauer <[email protected]>
Date: Tue, 30 Aug 2022 17:40:15 +0000
I don't know anything about the platform you are using, but I have a compact CA service I wrote years ago that uses around 29K and runs on some low-end Rabbit-based modules with just 512K flash and 512K SRAM and running at 22 MHz.  These controllers are running a "soft" RTOS I wrote based on the standard POSIX-compliant APIs used in Unix and Linux systems.
From: Tech-talk <[email protected]> on behalf of Florian Feldbauer via Tech-talk <[email protected]>
Sent: Tuesday, August 30, 2022 5:52 AM
To: [email protected] <[email protected]>
Subject: EPICS on ESP32
Hey all,
for a small side project I'm working with a board featuring an
ESP32-WROOM-32E module [1].
The module itself has WiFi and an EMAC core which is connected to an
ethernet PHY on the board (10/100Mbps).
Also there are some sensors connected to the module.
At the moment I have a small program running on the board, that connects
to ethernet, gets it's IP via DHCP and starts listening on a TCP port.
If a message is received the corresponding sensor data is send as an answer.
The chip is running a modified FreeRTOS kernel and I started to wonder,
if it would be possible to port EPICS on that module.
Does anyone have experience with the ESP32 and tried running EPICS on it
already?
If not, anyone has an idea for a good starting point for such a project?
A CA server that provides the sensor data as PVs would be enough.
Cheers,
Florian
[1]
https://urldefense.com/v3/__https://www.espressif.com/sites/default/files/documentation/esp32-wroom-32e_esp32-wroom-32ue_datasheet_en.pdf__;!!HXCxUKc!2ExLXTOwxKlloh0j1aNEYMaLFwWsJV757H7enJ49agHGy7y7Dg8CC463Zx-RnISjBTRAMQrjnVLP_0h8awfClnk$
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://urldefense.com/v3/__https://paluma.ruhr-uni-bochum.de__;!!HXCxUKc!2ExLXTOwxKlloh0j1aNEYMaLFwWsJV757H7enJ49agHGy7y7Dg8CC463Zx-RnISjBTRAMQrjnVLP_0h83l0XZMM$
Re: EPICS on ESP32 Siddons, David via Tech-talk
EPICS on ESP32 Florian Feldbauer via Tech-talk
Prev: Re: EPICS on ESP32 Eric Norum via Tech-talk
Next: Re: EPICS on ESP32 Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
