1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: EPICS on ESP32
From: Florian Feldbauer via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 31 Aug 2022 10:41:14 +0200
Hey Ralph,
yeah you are right, if I had to implement it myself I would go for UDP just like we do on our FPGAs.
But Espressif ships its own version of the Lightweight TCP/IP Stack so for me using TCP is just one line.
A common usage of those chips seems to be running a webserver (http(s)) on the chip to access data and control from the outside (at least this was a common thing in most example applications I had a look at)
Cheers,
Florian
On 8/31/22 10:16, Ralph Lange via Tech-talk wrote:
On Wed, 31 Aug 2022 at 09:50, Florian Feldbauer via Tech-talk <[email protected]> wrote:
Btw Eric, why do you think UDP would be more appropriate than TCP?
While not being Eric, I would argue that UDP is much simpler. Fire-and-forget instead of connection handling, buffering, re-transmitting, ...
For embedded applications on a limited OS or without OS (think FPGA et al.) that don't have huge amounts of data, periodically sending a UDP message to a configurable address/port is about the most simple and robust thing you can do.
Cheers,
~Ralph
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
EPICS on ESP32 Florian Feldbauer via Tech-talk
Re: EPICS on ESP32 Eric Norum via Tech-talk
Re: EPICS on ESP32 Florian Feldbauer via Tech-talk
Re: EPICS on ESP32 Ralph Lange via Tech-talk
Prev: Re: EPICS on ESP32 Ralph Lange via Tech-talk
Next: Re: EPICS on ESP32 Steve Hunt via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
