1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: EPICS on ESP32
To: Ralph Lange <[email protected]>
Date: Wed, 31 Aug 2022 10:48:52 +0200
I am also looking at FreeRTOS, but for a STM32 microcontroller.
I would think the way to go would be to write a standard TCP/IP sockets interface layer to the underlyng vendor specific network calls - unfortunately I have very limited time to look at this myself, it will be a low priority task. any thoughts?
Steve Hunt
Quoting Ralph Lange via Tech-talk <[email protected]>:
On Wed, 31 Aug 2022 at 09:50, Florian Feldbauer via Tech-talk <[email protected]> wrote:
Btw Eric, why do you think UDP would be more appropriate than TCP?
While not being Eric, I would argue that UDP is much simpler. Fire-and-forget instead of connection handling, buffering, re-transmitting, ...
For embedded applications on a limited OS or without OS (think FPGA et al.) that don't have huge amounts of data, periodically sending a UDP message to a configurable address/port is about the most simple and robust thing you can do.
Cheers,
~Ralph
EPICS on ESP32 Florian Feldbauer via Tech-talk
Re: EPICS on ESP32 Eric Norum via Tech-talk
Re: EPICS on ESP32 Florian Feldbauer via Tech-talk
Re: EPICS on ESP32 Ralph Lange via Tech-talk
Prev: Re: EPICS on ESP32 Florian Feldbauer via Tech-talk
Next: Re: [EXTERNAL] PyDevice modbus Vodopivec, Klemen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: EPICS on ESP32 Eric Norum via Tech-talk
