1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Basic iocStats database
From: Sean Leavey via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 7 Sep 2022 11:05:41 +0100
Hi Mark,
Thanks, that worked (mostly - see below)!
For anyone else interested, here is everything I did to create an app with iocStats support after compiling EPICS Base 7 and iocStats as a support module (hope I didn't miss anything):
$ mkdir /path/to/new/ioc
$ makeBaseApp.pl -t ioc myioc
$ makeBaseApp.pl -t ioc -i myioc
$ cd configure
$ nano RELEASE  # define paths to EPICS_BASE and IOCSTATS
$ cd ..
$ nano myiocApp/src/Makefile # add `myioc_DBD += devIocStats.dbd` and `myioc_LIBS += devIocStats`
$ make
$ cd iocBoot/iocmyapp
$ nano st.cmd # add `dbLoadRecords("/path/to/iocStats/db/iocAdminSoft.db", "IOC=MYIOC")`
$ ../../bin/linux-x86_64/myioc st.cmd  # runs softIOC
One thing that didn't work for me were the variables $(DEVIOCSTATS) and $(PREFIX), so I had to hard-code them above. When I start the IOC I get the following errors:
macLib: macro DEVIOCSTATS is undefined (expanding string dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)")) macLib: macro PREFIX is undefined (expanding string dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)"))
I guess I need to do something to ensure these are defined?
Another thing is the steps in [1] mention to compile MSI support, but I found this was already available on my path after installing EPICS Base. I skipped editing CONFIG_SITE to define MSI and it all appeared to still work.
Cheers,
Sean
[1] https://www.slac.stanford.edu/grp/ssrl/spear/epics/site/devIocStats/
On 02/09/2022 14:48, Mark Rivers wrote:
Hi Sean,
To load the iocStats records in your IOC you just need to build your application with the iocStats dbd and library files like this:
     $(DBD_NAME)_DBD += devIocStats.dbd
     PROD_LIBS        += devIocStats
And add a command like this to your IOC startup script:
*From:* Tech-talk <[email protected]> on behalf of Sean Leavey via Tech-talk <[email protected]>
*Sent:* Friday, September 2, 2022 8:25 AM
*To:* [email protected] <[email protected]>
*Subject:* Basic iocStats database
Hi all,
Following on from my first question a couple weeks ago about the
feasibility of setting up EPICS for a small lab, I've provisioned a
Debian 11 VM and gotten EPICS Base set up. While I wait for the arrival
of the Modbus-based sensors I plan to use EPICS to read, I thought I'd
set up iocStats
(https://www.slac.stanford.edu/grp/ssrl/spear/epics/site/devIocStats/ <https://www.slac.stanford.edu/grp/ssrl/spear/epics/site/devIocStats/>)
so I have some real world values to play with - CPU usage, etc.
Following various guides I've managed to compile the example application
with iocStats module support. However, I don't actually have any of the
records provided by iocStats configured, and that's where I've gotten
stuck. What I'd really like to see are examples of databases others have
made that make use of the various records provided by iocStats (if such
an example is provided with iocStats itself, I missed it). Ultimately I
want to be able to caget my VM's CPU load, so I can play with archiving
and plotting it later. Google has failed me so I thought I'd ask here.
So, is anyone willing to share their iocStats configurations with me?
Cheers,
Sean
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: Basic iocStats database Mark Rivers via Tech-talk
Basic iocStats database Sean Leavey via Tech-talk
Prev: Re: 'CAS-client' failed in ../db/dbEvent.c line 540 Oleg Makarov via Tech-talk
Next: Re: Basic iocStats database Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Basic iocStats database Mark Rivers via Tech-talk
