1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Understanding EPICS_CA_ADDR_LIST and caget
From: Sean Leavey via Tech-talk <[email protected]>
Date: Thu, 8 Sep 2022 13:52:49 +0100
Hi Jörn and Jure,
Thanks a lot for your input - it's helped me understand what the problem is. As you guessed, the reason I was looking into this was because caget was not managing to talk to my IOC, and it looks from the commands you pointed me to that some router/firewall is indeed trapping the connection.
Cheers,
Sean
On 08/09/2022 10:40, Jörn Dreyer via Tech-talk wrote:
Hi Sean,
some more suggestions on the network issue. Normally between two subnets there
is a firewall setup that blocks all traffic besides some ports and all
broadcasts. To figure out if you can reach the IOC you could use nmap like
this:
nmap -p 5064  195.194.120.115
If that does not find the port to be in open state, you will either need to ask
your IT to open that port on the firewall, or set up an EPICS gateway on a PC
that has two NICs into the two subnets.
Issue the nmap command on both machines. At least on the machine running the
IOC the port should be reported to be open.
This would be my first tests in such a case.
Regards
Jörn
Am Donnerstag, 8. September 2022, 11:23:37 CEST schrieb Jure Varlec via Tech-
talk:
Hello Sean,
As long as you have EPICS_CA_AUTO_ADDR_LIST set to YES, broadcast searches
will be done in addition to what you have specified in EPICS_CA_ADDR_LIST.
In other words, both broadcast searches to broadcast-capable interfaces and
unicast searches to explicitly listed addresses will happen. More
information on how this works is available in the CA Reference Manual,
which is linked at the bottom of the page that you referenced in your
message. And also below 🙂
https://epics.anl.gov/base/R3-14/12-docs/CAref.html#EPICS
This explains why you still see broadcast searches done on your first
interface. You should also see broadcasts on the other interfaces, and
unicast searches as well. But you do not, because tcpdump will only listen
on the first interface by default. You should tell it to listen on any
interface, it will give you a wider picture of what's going on.
Best,
Jure
From: Tech-talk <[email protected]> on behalf of Sean Leavey via
  Sent: Thursday, September 8, 2022 10:20
To: [email protected] <[email protected]>
Subject: Understanding EPICS_CA_ADDR_LIST and caget
Caution: This email originated from outside of Cosylab.
Hi tech talkers,
I don't seem to be able to change the behaviour of caget using
EPICS_CA_ADDR_LIST. I'm probably misunderstanding something.
I've got EPICS Base installed on my machine. In one terminal I've got
tcpdump monitoring port 5064. In another terminal I run caget with a
made-up channel. Here's their output after I run caget:
$ caget FAKE:CHANNEL
Channel connect timed out: 'FAKE:FAKE' not found.
$ tcpdump port 5064
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on wlan0, link-type EN10MB (Ethernet), snapshot length 262144
bytes
09:11:07.345310 IP totoro.41026 > 172.16.15.255.ca-1: UDP, length 48
09:11:07.377158 IP totoro.41026 > 172.16.15.255.ca-1: UDP, length 48
09:11:07.441438 IP totoro.41026 > 172.16.15.255.ca-1: UDP, length 48
09:11:07.569269 IP totoro.41026 > 172.16.15.255.ca-1: UDP, length 48
09:11:07.825253 IP totoro.41026 > 172.16.15.255.ca-1: UDP, length 48
So far, so good? Looks like caget is sending 5 broadcast packets then
giving up. 172.16.15.255 is my link's broadcast address, verified with
`ip addr`.
But what if I know the IP of the IOC that hosts a channel, and want to
specify it directly? I read in [1]:
  > To reach IOCs on one or more additional subnets, the environment
variable EPICS_CA_ADDR_LIST needs to be configured. It can list either
the specific IP addresses of each IOC, or the broadcast address of their
subnet. Note, however, that routers will often not forward broadcast
requests, which suggests using specific IP addresses.
This sounds useful to me because my IOC is in a different subnet. From
the quoted text above, I understand that, by setting EPICS_CA_ADDR_LIST
to the IP of my IOC, caget should talk directly to it. But apparently
this is not the case. Keeping tcpdump open, and running the caget
command again but this time with the address of my IOC set in
EPICS_CA_ADDR_LIST, I get the same output:
$ EPICS_CA_ADDR_LIST=195.194.120.115 caget FAKE:FAKE
$ tcpdump port 5064
09:14:18.995465 IP totoro.35942 > 172.16.15.255.ca-1: UDP, length 48
09:14:19.027341 IP totoro.35942 > 172.16.15.255.ca-1: UDP, length 48
09:14:19.091486 IP totoro.35942 > 172.16.15.255.ca-1: UDP, length 48
09:14:19.219462 IP totoro.35942 > 172.16.15.255.ca-1: UDP, length 48
09:14:19.475597 IP totoro.35942 > 172.16.15.255.ca-1: UDP, length 48
Clearly I'm misunderstanding how all of this works. Can someone shed
some light on what EPICS_CA_ADDR_LIST does in the context of caget, if
anything?
Cheers,
Sean
[1]
https://epics-controls.org/resources-and-support/documents/howto-documents/c
onfigure-channel-access/#IOCs_on_different_subnets
This email and any attachments are intended solely for the use of the named
recipients. If you are not the intended recipient you must not use,
disclose, copy or distribute this email or any of its attachments and
should notify the sender immediately and delete this email from your
system. UK Research and Innovation (UKRI) has taken every reasonable
precaution to minimise risk of this email or any attachments containing
viruses or malware but the recipient should carry out its own virus and
malware checks before opening the attachments. UKRI does not accept any
liability for any losses or damages which the recipient may sustain due to
presence of any viruses.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: Understanding EPICS_CA_ADDR_LIST and caget Mark Rivers via Tech-talk
Understanding EPICS_CA_ADDR_LIST and caget Sean Leavey via Tech-talk
Re: Understanding EPICS_CA_ADDR_LIST and caget Jure Varlec via Tech-talk
Re: Understanding EPICS_CA_ADDR_LIST and caget Jörn Dreyer via Tech-talk
Prev: Getting a time series of some NDPluginStats Iain Marcuson via Tech-talk
Next: Re: Understanding EPICS_CA_ADDR_LIST and caget Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Understanding EPICS_CA_ADDR_LIST and caget Jörn Dreyer via Tech-talk
