1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows
From: Carsten Winkler via Tech-talk <[email protected]>
Date: Tue, 13 Sep 2022 08:45:39 +0200
Hello tech-talkers,
I have the following situation. My computer is running MS Windows and several SoftIOCs (EPICS BASE 7.0.6.1). Furthermore, there is a CA gateway in the local network.
Without EPICS environment variables I get the following results:
cainfo TestPV:aiExample
CA.Client.Exception...............................................
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "TestPV:aiExample", Connecting to: my_computer.bessy.de:5064, Ignored: ca_gateway.bessy.de:5064"     Source File: D:\epics\epics-base-R7.0.6.1\modules\ca\src\client\cac.cpp line 1320
    Current Time: Tue Sep 13 2022 08:19:36.713908800
TestPV:aiExample
    State:            connected
    Host:             my_computer.bessy.de:5064
    Access:           read, write
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    1
cainfo TestPV:ai1
TestPV:ai1
    State:            connected
    Host:             my_computer.bessy.de:62425
    Access:           read, write
    Element count:    1
    Context: "Channel: "TestPV:ai1", Connecting to: my_computer.bessy.de:62425, Ignored: ca_gateway.bessy.de:62425"     Source File: D:\epics\epics-base-R7.0.6.1\modules\ca\src\client\cac.cpp line 1320
    Current Time: Tue Sep 13 2022 08:19:27.881409000
Okay, lets fix the issue "Identical process variable names on multiple servers".
set EPICS_CA_ADDR_LIST=ca_gateway.bessy.de
set EPICS_CA_AUTO_ADDR_LIST=NO
Now I get following results:
TestPV:aiExample
    State:            connected
    Host:             ca_gateway.bessy.de:5064
    Access:           read, write
    Element count:    1
cainfo TestPV:ai1
Channel connect timed out: 'TestPV:ai1' not found.
Obviously the variables from the second SoftIOC with port 62425 are not found anymore. I have the same problem when I enter the address of the client computer in the EPICS_CA_ADDR_LIST.
How do I solve this problem?
Cheers,
Carsten
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
Prev: asyn R4-43 released Mark Rivers via Tech-talk
Next: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Carsten Winkler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
