Hi Jörn
What makes you think that only GPIB and RS232 are supported?
has these lines:
## For IP Asyn support
## DG645
#drvAsynIPPortConfigure("serial1","x.x.x.x:5025",0,0,0)
which has these comments.
### Stanford Research Systems (SRS) DG645
# You can use the serial port or the network port, as in the main st.cmd.
So it looks to me like the network port is supported.
Hello
I was looking into the synApps:delyagen module because we have a couple of
Stanford Resarch DG645 boxes in our facility that we would like to control
from EPICS. Currently the driver support GPIB and RS232 interfaces. What about
the ethernet interface? Do you know if someone is working on porting the
driver to be an AsynPortDriver derived class?
Jörn
- Question regarding synApps:delaygen Jörn Dreyer via Tech-talk
Re: Process a record only when IOC shell exits Andrew Johnson via Tech-talk
<2022>
2025
2026
Re: mbboDirect Bx fields don't update on alarm change Sue Witherspoon via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
