1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Question regarding synApps:delaygen module
To: tech-talk <[email protected]>, Jörn Dreyer <[email protected]>
Date: Fri, 16 Sep 2022 03:55:10 +0000
Hi Jörn,
I am not sure if tech-talk may still be having issues, but I responded to your previous post of this message earlier today.
Hi Jörn
What makes you think that only GPIB and RS232 are supported?
has these lines:
## For IP Asyn support
## DG645
#drvAsynIPPortConfigure("serial1","x.x.x.x:5025",0,0,0)
This implies support for Ethernet.  That st.cmd loads this db645.cmd file https://github.com/epics-modules/delaygen/blob/master/iocBoot/iocdelaygen/dg645.cmd
which has these comments.
### Stanford Research Systems (SRS) DG645
# You can use the serial port or the network port, as in the main st.cmd.
So it looks to me like the network port is supported.
From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
Sent: Thursday, September 15, 2022 10:43 PM
Subject: Question regarding synApps:delaygen module
Hello
I was looking into the synApps:delyagen module because we have a couple of
Stanford Resarch DG645 boxes in our facility that we would like to control
from EPICS. Currently the driver support GPIB and RS232 interfaces. What about
the ethernet interface? Do you know if someone is working on porting the
driver to  be an AsynPortDriver derived class?
Jörn
Question regarding synApps:delaygen module Jörn Dreyer via Tech-talk
Prev: Question regarding synApps:delaygen module Jörn Dreyer via Tech-talk
Next: RE: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: pyepics get_with_metadata inconstant behaviour Marco A. Barra Montevechi Filho via Tech-talk
