Good evening!
We are perceiving a strange behaviour with get_with_metadata method in pyepics here.
We have a motor record PV with defined PREC and EGU fields. We have a script that goes:
my_pv = epics.PV("MGN:B:PB01:CS7:m4")
my_dict = my_pv.get_with_metadata(use_monitor=True)
First weird behaviour: between the many values returned in my_dict, the "precision" key is associated with "None" value and the same goes for "unit" key:
{'pvname': 'MGN:B:PB01:CS7:m4', 'value': 3.56963, 'char_value': '3.56963', 'status': 0, 'ftype': 20, 'chid': 28543096, 'host': '10.10.10.38:46317', 'count': 1, 'access': 'read/write', 'write_access': True, 'read_access': True, 'severity': 0, 'timestamp': 1663352086.023605,
'posixseconds': 1663352086.0, 'nanoseconds': 23605915, 'precision': None, 'units': None, 'enum_strs': None, 'upper_disp_limit': None, 'lower_disp_limit': None, 'upper_alarm_limit': None, 'lower_alarm_limit': None, 'lower_warning_limit': None, 'upper_warning_limit':
None, 'upper_ctrl_limit': None, 'lower_ctrl_limit': None, 'nelm': 1, 'type': 'time_double', 'typefull': 'time_double'}
Second weird behaviour: when executed several times, dictionaries with different number of keys are returned. Changing use_monitor=False limited the dictionary size to
{'status': 0, 'severity': 0, 'timestamp': 1663353141.426072, 'posixseconds': 1663353141.0, 'nanoseconds': 426072330, 'value': 3.56963}
and the number of keys does not vary, but now we dont have precision and unit, which would be useful. Are we doing something wrong? Where does get_with_metadata gets its information from? Shouldnt "unit" come from EGU field?
I couldnt find answers for that in the documentation. Thanks for any help
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta
ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying
to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
