1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Question about alias name
From: Michael Davidsaver via Tech-talk <[email protected]>
Date: Fri, 16 Sep 2022 11:35:29 -0700
On 9/15/22 20:00, lzfneu--- via Tech-talk wrote:
Dear all,
I try to use alias name for my existed pv names, part of the record are as follows:
record (calc, "test")
     alias("test:alias_name")
     field(INPA,"test_pv.VAL")
     field(ADEL, "-1")
     field(CALC, "A*10")
     field(EGU, "m")
     field(FLNK, "test2")
record(calc, "test2")
When I run the IOC, I received the following errors:
ErrorCan't create alias "test:alias_name" for "test" Error at or before ")" in file "db/ai.template" line XX.
And XX is the alias filed line number.
Although showed the error messages, the alias PV name "test:alias_name" can normally receive the same data as PV name "test". I have no idea how to correct the error messages.
Any help will be appreciated and thanks in advance.
What version of EPICS Base are you using?
I'm not able to replicate with 7.0.7
$ cat alias.db record (calc, "test")
        field(ADEL, "-1")
        field(CALC, "A*10")
        field(EGU, "m")
}> $ softIoc -d alias.db Starting iocInit
## EPICS R7.0.6.2-DEV
## Rev. R7.0.6.1-260-ga0a937d0b6ce07c20358
## Rev. Date Git: 2022-09-03 11:36:57 -0700
Forward-link uses Channel Access without pointing to PROC field
    test.FLNK => test2
epics>
Re: Question about alias name neu lzf via Tech-talk
Question about alias name lzfneu--- via Tech-talk
Prev: RE: [EXTERNAL] Re: EPICS_CA_ADDR_LIST and multiple instances of a SoftIOC on Windows Mark Rivers via Tech-talk
Next: pyepics get_with_metadata inconstant behaviour Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Question about alias name lzfneu--- via Tech-talk
Next: Re: Question about alias name neu lzf via Tech-talk
