1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: mbboDirect Bx fields don't update on alarm change
From: Andrew Johnson via Tech-talk <[email protected]>
To: Sue Witherspoon <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 16 Sep 2022 14:19:09 -0500
Hi Sue,
On 9/15/22 6:34 PM, Sue Witherspoon via Tech-talk wrote:
     Was there ever a 'fix' for this?  I have a very simply db  where a mbboDirect feeds and AO record. The AO record writes to HW. During normal
operations the Bits are toggled on/off and that works. But during a maintenance period the engineers want to enter an integer value.  This does
not work anymore. It worked in 3.14 but now in 3.15 it doesn't.
I believe this is related to what Andrew was describing: https://epics.anl.gov/tech-talk/2021/msg01619.php
Did the Epics experts every resolve this?
I suspect this 2012 commit to the 3.15 branch caused the breakage that you are seeing (mea culpa, sorry!), but I haven't looked at it in detail to confirm that.
There were commits made to the mbboDirect record on the 7.0 branch in September-October 2021 after the above tech-talk conversation. The release notes for EPICS 7.0.6.1 said:
mbboDirectRecord enhancements
The bit fields B0 - B1F of this record are now always updated and have a monitor posted when the VAL field is set and the record processed. It is now possible to initialize the record's value by setting the bit fields inside a database file as long as no other method was used to initialize it (suc as setting VAL directly, using DOL, or by an initial readback from device support). A new internal field OBIT was added to store information about monitors posted on the bit fields.
However we have not made any similar changes to the record type on the 3.15 branch, and I don't think the core developers would have time to do so, although we would probably accept and merge a pull request for a back-port of those changes from the 7.0 branch to 3.15 for sites that can't upgrade to EPICS 7.
This is the behavior I'm seeing from an IOC running EPICS 7.0.6.1, which matches your 3.14.11 results:
tux% caget MbboRec.VAL
MbboRec.VAL                    0
tux% caput MbboRec.VAL 2048
Old : MbboRec.VAL                    0
New : MbboRec.VAL                    2048
tux% caput MbboRec.BB 0
Old : MbboRec.BB                     1
New : MbboRec.BB                     0
tux% caput MbboRec.BC 1
Old : MbboRec.BC                     0
New : MbboRec.BC                     1
MbboRec.VAL                    4096
We haven't made a release from the 3.15 branch for about a year now and one is due, so back-porting this fix would give us a reason to do that.
HTH,
- Andrew
Complexity is free, it's Simplicity that takes work.
Re: mbboDirect Bx fields don't update on alarm change Sue Witherspoon via Tech-talk
Prev: pyepics get_with_metadata inconstant behaviour Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: pyepics get_with_metadata inconstant behaviour Matt Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: mbboDirect Bx fields don't update on alarm change Sue Witherspoon via Tech-talk
Next: Question about alias name lzfneu--- via Tech-talk
