1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: pyepics get_with_metadata inconstant behaviour
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
To: Matt Newville <[email protected]>
Cc: Lucca Bavia Cuenca Campoi <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 16 Sep 2022 19:55:12 +0000
Thanks, Matt!
Indeed it worked here. A colleague of mine also suggested using ophyd with .describe() and .get() methods and indeed it works well too.
Thanks for the help,
Marco
Sent: 16 September 2022 16:46
To: Marco A. Barra Montevechi Filho <[email protected]>
Cc: [email protected] <[email protected]>; Lucca Bavia Cuenca Campoi <[email protected]>
Hi Marco,
On Fri, Sep 16, 2022 at 1:38 PM Marco A. Barra Montevechi Filho via Tech-talk <[email protected]> wrote:
Good evening!
We are perceiving a strange behaviour with get_with_metadata method in pyepics here.
We have a motor record PV with defined PREC and EGU fields. We have a script that goes:
my_pv = epics.PV("MGN:B:PB01:CS7:m4")
my_dict = my_pv.get_with_metadata(use_monitor=True)
First weird behaviour: between the many values returned in my_dict, the "precision" key is associated with "None" value and the same goes for "unit" key:
{'pvname': 'MGN:B:PB01:CS7:m4', 'value': 3.56963, 'char_value': '3.56963', 'status': 0, 'ftype': 20, 'chid': 28543096, 'host': '10.10.10.38:46317', 'count': 1, 'access': 'read/write', 'write_access': True, 'read_access': True, 'severity': 0, 'timestamp': 1663352086.023605, 'posixseconds': 1663352086.0, 'nanoseconds': 23605915, 'precision': None, 'units': None, 'enum_strs': None, 'upper_disp_limit': None, 'lower_disp_limit': None, 'upper_alarm_limit': None, 'lower_alarm_limit': None, 'lower_warning_limit': None, 'upper_warning_limit': None, 'upper_ctrl_limit': None, 'lower_ctrl_limit': None, 'nelm': 1, 'type': 'time_double', 'typefull': 'time_double'}
Second weird behaviour: when executed several times, dictionaries with different number of keys are returned. Changing use_monitor=False limited the dictionary size to
{'status': 0, 'severity': 0, 'timestamp': 1663353141.426072, 'posixseconds': 1663353141.0, 'nanoseconds': 426072330, 'value': 3.56963}
and the number of keys does not vary, but now we dont have precision and unit, which would be useful. Are we doing something wrong? Where does get_with_metadata gets its information from? Shouldnt "unit" come from EGU field?
I couldnt find answers for that in the documentation. Thanks for any help 🙂
Sorry for the confusion!
For each PV in Channel Access, there are a few choices in "record type":  "plain", "severity", "time", "control", and "graphics" (I might be missing one or two).  These will change which set of metadata can be retrieved with the data.
If I recall correctly, "severity" is a subset of "time" and "graphics" is a subset of "control".   "plain" gives no extra metadata, "time" gives timestamp, alarm, and severity, and "control" giving lots of metadata, but importantly not the timestamp.
In pyepics, there is a choice of this record type (called "form" in the pyepics code and docs, as "type" is a builtin in Python), with "time" being the default, "plain" and "ctrl" being available.   That is
    mypv = epics.PV(pvname, form='ctrl')
will create a PV with all the control metadata available but by default
will create a PV with time metadata.   Even for a "time" PV, doing `mypv.get_ctrlvars()` will return the "control" metadata (precision, limits, etc).
`mypv.get_with_metadata()` will try to give all the available metadata, but it might not explicitly look those up - it might rely on cached values from the last monitor event.   The intention for the `use_monitor` option for  `mypv.get_with_metadata()` is to control whether those cached values are used, but it does seem to be doing something incorrectly: I'll investigate.
I think that the best way to get an accurate and complete set of all the metadata, use
   mypv.get_with_metadata(with_ctrlvars=True)
That will really do a fetch of the current values of the control metadata, or to get the control metadata with
   mypv.get_ctrlvars()
Again, sorry for the confusion.
--Matt
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
pyepics get_with_metadata inconstant behaviour Marco A. Barra Montevechi Filho via Tech-talk
Re: pyepics get_with_metadata inconstant behaviour Matt Newville via Tech-talk
Prev: Re: pyepics get_with_metadata inconstant behaviour Matt Newville via Tech-talk
Next: Re: PVXS release 1.0.0 and P4P 4.1.2 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: rpc.h of Asyn not found in Rocky 9 网易邮件中心 via Tech-talk
