1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: warnings.warn from raspberry pyepics
To: LE-DANIEL Erwann <[email protected]>
Cc: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 19 Sep 2022 15:29:50 +0000
When you say it runs 10 seconds does it work correctly during that time, printing that values? Or does it just hang for 10 seconds?
You can print additional information about p after you create it, like whether it is connected to the PV.
Sent from my iPhone
On Sep 19, 2022, at 7:18 AM, LE-DANIEL Erwann via Tech-talk <[email protected]> wrote:
Hello,
I’m using a raspberry to get epics variable value from that code :
import epics
import time
while True:
               p=epics.PV(‘TL_AN_Input’)
               val = p.get()
               print (val)
               time.sleep(0.1)
This code runs about 10 seconds and after it returns the error message :
/home/pi/.local/lib/python3.9/site-packages/epics/ca.py:1528: UserWarning: ca.get(‘TL_AN_Input…’) timed out after 1.00 seconds.
Warnings.warn(msg % (name(chid), timeout))
What does it mean ?
Is it because I need to clean the PV_cache ?  è if it is the case how can I do that ?
Thank you very much.
Cordialement,
LE DANIEL Erwann.
CONFIDENTIALITY : This e-mail and any attachments are confidential and may be privileged. If you are not a named recipient, please notify the sender immediately and do not disclose the contents to another person, use it for any purpose or store or copy the information in any medium.
RE: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
Prev: Cant caget from different IOC server Marco A. Barra Montevechi Filho via Tech-talk
Next: RE: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
