1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: Cant caget from different IOC server
From: "Marco A. Barra Montevechi Filho via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 19 Sep 2022 14:42:33 +0000
Hello all.
I have two IOC servers and inside server 1 im trying to caget a PV from server 2. They are not in the same subnet.
I can caget PVs from server 2 from other servers so im guessing problem is in server 1. Inside server 1 i make:
export EPICS_CA_ADDR_LIST="$EPICS_CA_ADDR_LIST <IP_from_server_2>"
caget <MY_PV>
and i get:
Channel connect timed out: '<MY_PV>' not found.
Server 2 is a Debian 9.11 and server 1 is Debian 10. nftables or iptables commands are not recognized in server 1 so i have no ideas on how to look for my firewall configurations.
Any tips on how to debug this? Thanks in advance 🙂
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Cant caget from different IOC server Sean Leavey via Tech-talk
Prev: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
Next: Re: warnings.warn from raspberry pyepics Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Prev: RE: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
Next: Re: Cant caget from different IOC server Sean Leavey via Tech-talk
ANJ, 20 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
