1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Cant caget from different IOC server
From: Sean Leavey via Tech-talk <[email protected]>
To: "Marco A. Barra Montevechi Filho" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 20 Sep 2022 09:16:07 +0100
Hi Marco,
I had some troubles caused by different subnets a couple of weeks ago: https://epics.anl.gov/tech-talk/2022/msg01375.php
Some commands are mentioned in that thread that can help diagnose what's going on on the network, e.g. tcpdump, nmap, etc.
Cheers,
Sean
On 19/09/2022 15:42, Marco A. Barra Montevechi Filho via Tech-talk wrote:
Hello all.
I have two IOC servers and inside server 1 im trying to caget a PV from server 2. They are not in the same subnet. I can caget PVs from server 2 from other servers so im guessing problem is in server 1. Inside server 1 i make:
export EPICS_CA_ADDR_LIST="$EPICS_CA_ADDR_LIST <IP_from_server_2>"
caget <MY_PV>
and i get:
Channel connect timed out: '<MY_PV>' not found.
Server 2 is a Debian 9.11 and server 1 is Debian 10. nftables or iptables commands are not recognized in server 1 so i have no ideas on how to look for my firewall configurations.
Any tips on how to debug this? Thanks in advance 🙂
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: Cant caget from different IOC server Marco A. Barra Montevechi Filho via Tech-talk
Prev: about me UDIT PANDEYGEE via Tech-talk
Next: Re: Cant caget from different IOC server Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Cant caget from different IOC server Marco A. Barra Montevechi Filho via Tech-talk
