1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: mbbo & calcout for drive position management
From: "Crisp, Daniel via Tech-talk" <[email protected]>
Date: Tue, 4 Oct 2022 18:10:27 +0000
Hey Ralph,
(I hope I'm responding to this thread correctly, I just changed my tech-talk subscription from nscl.msu.edu to frib.msu.edu)
Well that sure makes a lot more sense, thanks!
I did run into an issue doing this, though. For reasons I don't understand, the IOC doesn't seem to like the following line in my mbbo definition:
field(DTYP, "Raw Soft")
At IOC startup, I get the following:
Can't set "REA_BTS41:STRIP_D1391:POS_SEL.DTYP" to "Raw Soft"
I figured I could take this support being there for granted.
If I grep my IOC for "Raw Soft" I get the following, which leads me to believe that it is in fact there, but maybe there's more to it?
dbd/rea-ops.dbd:device(mbbo, CONSTANT, devMbboSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(bo, CONSTANT, devBoSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(mbbi, CONSTANT, devMbbiSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(bi, CONSTANT, devBiSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(mbbiDirect, CONSTANT, devMbbiDirectSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(mbboDirect, CONSTANT, devMbboDirectSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(ai, CONSTANT, devAiSoftRaw, "Raw Soft Channel")
dbd/rea-ops.dbd:device(ao, CONSTANT, devAoSoftRaw, "Raw Soft Channel")
(these device() lines are also seen in my rea-opsApp/src/O.Common/rea-ops.dbd file)
Am I missing something here?
Thanks again!
-Dan
Re: mbbo & calcout for drive position management Andrew Johnson via Tech-talk
Prev: Control System Engineer position at ALS in LBNL Miroslaw Dach via Tech-talk
Next: Re: mbbo & calcout for drive position management Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: mbbo & calcout for drive position management Ralph Lange via Tech-talk
