1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Read and Write errors with VME-EVR-300
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Hong, Ran" <[email protected]>
Date: Wed, 5 Oct 2022 08:56:32 -0700
On 10/3/22 17:29, Hong, Ran via Tech-talk wrote:
Hello All,
I am testing a VME IOC with 1 VME-EVM-300 and 6 VME-EVR-300 boards. The CPU board is mvme-3100, and the driver is derived from mrfioc2:
https://github.com/epics-modules/mrfioc2 <https://github.com/epics-modules/mrfioc2>
I experienced many errors like missing time stamp, incorrect GTX waveform, and so on. They all stem from issues when reading from or writing to VME registries using READ32 or WRITE32 in the driver. For example, in evrMrmApp/src/drvem.cpp line 803 to 806 for latching the timestamp,
epicsUInt32 ctrl=READ32(base, Control);
It should be noted that this is with vxWorks.
//Latch timestamp
WRITE32(base, Control, ctrl|Control_tsltch);
It reads the control registry, modify the bit for timestamp latch, and write it back to the control registry. Occasionally, I saw the READ32 returns 0xffffffff, which is an invalid value for the control registry, and the subsequent WRITE32 results in a mess in the EVR.
Has anyone experienced similar issues? Any suggestions to prevent or mitigate the VME I/O errors?
There was an issue with the VME logic which manifest
most often as a bus error when reading this register.
However, this issue was isolated and fix back in Feb.
2011.
Jukka may remember better.  As I recall, the root
cause was a FW issue during the arbitration part
of a VME cycle whereby one MRF card would pull the
bus error line during an operation intended to access
another.  So it only manifest when more than one
MRF card were present.
https://github.com/epics-modules/mrfioc2/blob/a8cb48d549b7aae13206cf2d168c6f1cfec2e1c4/evrMrmApp/src/drvem.cpp#L811-L817
Talking of seeing a change when a separate card is
acting as VME arbiter make me wonder if a similar
sort of issue has arisen.
(software has very little involvement in VME bus
Re: Read and Write errors with VME-EVR-300 Michael Davidsaver via Tech-talk
Re: Read and Write errors with VME-EVR-300 Andrew Johnson via Tech-talk
Read and Write errors with VME-EVR-300 Hong, Ran via Tech-talk
Prev: PVXS and Phoebus Florian Feldbauer via Tech-talk
Next: Re: Read and Write errors with VME-EVR-300 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Read and Write errors with VME-EVR-300 Wang, Lin via Tech-talk
