1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Read and Write errors with VME-EVR-300
From: "Wang, Lin via Tech-talk" <[email protected]>
To: "hong, ran" <[email protected]>
Date: Wed, 5 Oct 2022 09:18:00 +0800 (GMT+08:00)
Hello Ran,
You may also want to take a look at the PSI clone of mrfioc2 as well as supported hardware and firmware. A couple of years ago we used the following driver to test our VME-EVM-300 and VME-EVR-300 under MVME-5100 / vxWorks6.8 environment.
https://github.com/paulscherrerinstitute/mrfioc2
Lin
-----Original Messages-----
Sent Time:2022-10-04 08:29:46 (Tuesday)
Cc:
Subject: [SPAM] Read and Write errors with VME-EVR-300
Hello All,
I am testing a VME IOC with 1 VME-EVM-300 and 6 VME-EVR-300 boards. The CPU board is mvme-3100, and the driver is derived from mrfioc2:
I experienced many errors like missing time stamp, incorrect GTX waveform, and so on. They all stem from issues when reading from or writing to VME registries using READ32 or WRITE32 in the driver. For example, in evrMrmApp/src/drvem.cpp line 803 to 806 for latching the timestamp,
epicsUInt32 ctrl=READ32(base, Control);
// Latch timestamp
WRITE32(base, Control, ctrl|Control_tsltch);
It reads the control registry, modify the bit for timestamp latch, and write it back to the control registry. Occasionally, I saw the READ32 returns 0xffffffff, which is an invalid value for the control registry, and the subsequent WRITE32 results in a mess in the EVR.
Has anyone experienced similar issues? Any suggestions to prevent or mitigate the VME I/O errors?
Thanks!
Ran Hong
Read and Write errors with VME-EVR-300 Hong, Ran via Tech-talk
Prev: Re: Read and Write errors with VME-EVR-300 Heinz Junkes via Tech-talk
Next: Re: Read and Write errors with VME-EVR-300 Hong, Ran via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Read and Write errors with VME-EVR-300 Michael Davidsaver via Tech-talk
Next: Re: Read and Write errors with VME-EVR-300 Michael Davidsaver via Tech-talk
