failed on CentOS 9 (GCC version 11.3.1, make version 4.3).
It seemed the error is related to C++ private/protected access specifiers.
I guess that the reason is because CentOS 9's newer GCC has tightened some rules.
Then the build succeed.
My question: is the above modification a proper fix to correct this build error.
In file included from ../../../../src/cas/generic/caServer.cc:21:
../../../../src/cas/generic/caServerI.h: At global scope:
../../../../src/cas/generic/caServerI.h:91:5: error: ‘class tsDLList<ioBlocked> tsDLList<ioBlocked>::tsDLList’ is private within this context
91 | tsDLList < casStrmClient > clientList;
In file included from ../../../../src/cas/generic/caServerI.h:33,
../../../../src/cas/generic/ioBlocked.h:43:7: note: declared private here
43 | class ioBlockedList : private tsDLList<ioBlocked> {
../../../../src/cas/generic/caServerI.h:92:5: error: ‘class tsDLList<ioBlocked> tsDLList<ioBlocked>::tsDLList’ is private within this context
92 | tsDLList < casIntfOS > intfList;
make[4]: *** [../../../../configure/RULES_BUILD:220: caServer.o] Error 1
make[4]: Leaving directory '/home/chiang.lc/base-3.14.12.8/src/cas/build/O.linux-x86_64'
make[3]: *** [../../../configure/RULES_ARCHS:61: install.linux-x86_64] Error 2
make[3]: Leaving directory '/home/chiang.lc/base-3.14.12.8/src/cas/build'
make[2]: *** [../../configure/RULES_DIRS:83: build.install] Error 2
make[2]: Leaving directory '/home/chiang.lc/base-3.14.12.8/src/cas'
make[1]: *** [../configure/RULES_DIRS:83: cas.install] Error 2
make[1]: Leaving directory '/home/chiang.lc/base-3.14.12.8/src'
make: *** [configure/RULES_DIRS:83: src.install] Error 2
