1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: EPICS 7 side-by-side with EPICS 3/4
From: Timo Korhonen via Tech-talk <[email protected]>
To: "Gregory, Ray" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 6 Oct 2022 09:37:30 +0000
Hi Ray,
An EPICS 7 IOC can run perfectly well side-to-side with older IOCs; you may not be able to use all the new features depending on how your other infrastructure looks like, but otherwise I do not see any big issues with that.
If you have a (version 3 type) record-based soft IOC, that should run on EPICS 7 without big issues, at least if you do not use custom drivers or such.
But are there some specific things that you would like to do with the EPICS 7 IOC?
Best regards,
Timo (ESS)
From: Tech-talk <[email protected]> on behalf of "Gregory, Ray via Tech-talk" <[email protected]>
Reply to: "Gregory, Ray" <[email protected]>
Date: Wednesday, 5 October 2022 at 19:58
Subject: EPICS 7 side-by-side with EPICS 3/4
At our ORNL neutron beamlines, we normally deploy EPICS 3.14.12.6 and EPICS 4.6.
I would like to create an EPICS 7 IOC to run side-by-side with the EPICS 3/4 IOCs we are normally running.
How can I do this for a typical database-based soft IOC? For a Python IOC?
Thank you,
Ray
Ray Gregory
Oak Ridge National Laboratory
EPICS 7 side-by-side with EPICS 3/4 Gregory, Ray via Tech-talk
Prev: EPICS Base 3.14.12.8 build error on CentOS 9 Chiang, Liang-Chih [江良志] via Tech-talk
Next: Re: EPICS Base 3.14.12.8 build error on CentOS 9 Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: EPICS 7 side-by-side with EPICS 3/4 Gregory, Ray via Tech-talk
Next: Custom Asyn motor driver hangs on any move after the first? Eloise de Castelnau via Tech-talk
