1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Exploring EPICS performance/processing limits
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
To: "Hu, Yong" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 6 Oct 2022 18:27:20 +0000
Hi, Hu! Thanks for the hint.
Since issue is that im trying to use a transform record to do several operations in sequence and im only using python to understand the IOC's capacity of processing several record values changes quickly, i think cothread is more of a diagnostics tool in this case than a fix to the problem.
I did follow your instructions nonetheless and the results were somewhat similar to expected. Here is the script:
#!/usr/bin/python3
import cothread
from cothread.catools import caput
caput(["MOBICDTE:Backend:ImgChipNumberID", "MOBICDTE:Backend:ImgChipNumberID",
    "MOBICDTE:Backend:ImgChipNumberID", "MOBICDTE:Backend:ImgChipNumberID"], [0, 1, 2, 3])
The tcpflow results skip both "params": [["1","1"]] and "params": [["1", "2"]] commands:
127.000.000.001.55780-127.000.000.001.60000: {"id":"1", "method":"HS_ImgChipNumberID_Command", "params": [["1", "0"]], "jsonrpc": "2.0"}
127.000.000.001.55780-127.000.000.001.60000: {"id":"1", "method":"HS_ImgChipNumberID_Command", "params": [["0"]], "jsonrpc": "2.0"}
127.000.000.001.55780-127.000.000.001.60000: {"id":"1", "method":"HS_ImgChipNumberID_Command", "params": [["1", "3"]], "jsonrpc": "2.0"}
And the camonitor didnt even show any signal. Nothing at all. Same as if i had just typed the camonitor command and did no operation at all with the PV:
camonitor MOBICDTE:Backend:ImgChipNumberID
MOBICDTE:Backend:ImgChipNumberID 2022-10-06 15:24:16.416637 3 READ INVALID
CA.Client.Exception...............................................
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "MOBICDTE:Backend:ImgChipNumberID", Connecting to: 192.168.55.1:5064, Ignored: s-mgn-mob01-l.abtlus.org.br:5064"
    Source File: ../cac.cpp line 1320
    Current Time: Thu Oct 06 2022 15:26:07.987693022
Sent: 06 October 2022 10:33
To: Marco A. Barra Montevechi Filho <[email protected]>; [email protected] <[email protected]>
Hello Marco,
To me, looping with “caput_one_pv_at_a_time” seems inefficient, especially in the Python world where “list” is a daily-usable data structure.
I have been using another Python-based Channel Access tool named “cothread” where you simply caput a list of pvs associated with a list of values: cothread.catools.caput(pvs, values). In your case, cothread.catools.caput(a_list_of_records, VALUE, repeat_value=True).
I have used “cothread” in one application where I get ~200 BPM waveform data (100K doubles per BPM) in a few seconds by caget(bpm_wavform_pv_list). Basically the processing time is dominated by the limited network bandwidth. “cothread” is very efficient by using cooperative threading.
Take a look at these links:
https://github.com/dls-controls/cothread
https://cothread.readthedocs.io/en/latest/catools.html#cothread.catools.caput
Cheers,
Yong
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Date: Wednesday, October 5, 2022 at 7:26 PM
To: [email protected] <[email protected]>
Subject: Exploring EPICS performance/processing limits
Hello all.
I bumped into something that may or may not be caused by EPICS default processing time limits and would like tips on how to explore it, if possible.
I have a set of records that send messages to a loopback ethernet address via a .proto file and stream device.
Lets say RECORD1 sends a string "message1 VAL1", RECORD2 sends "message2 VAL2", etc.
I was monitoring the traffic with ´tcpflow -c -i <my_IP> port <my_PORT> | grep "message"´ and made a python script in the form:
import epics, time
def do_thing(x):
    for record in ["RECORD1", "RECORD2", "RECORD3", "RECORD4"]:
        epics.caput(record, VALUE)
        time.sleep(x)
The messages i got from tcpflow when executing the python script with do_thing(1.5) were nicely formatted:
message1 VALUE
message2 VALUE
message3 VALUE
message4 VALUE
But when i do the same thing with x=0.5, messages 2 and 3 were sometimes missing or sometimes badly formatted. Sometimes i got things like:
message1 VALUE
message2
message3
message4 VALUE
And sometimes like:
message1 VALUE
message4 VALUE
Is this a PV processing time issue? Shouldnt the IOC be capable of dealing with time intervals smaller than this? Is there a way i can improve this behaviour without setting sleep times between my caputs?
Thanks in advance,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Exploring EPICS performance/processing limits Marco A. Barra Montevechi Filho via Tech-talk
Re: Exploring EPICS performance/processing limits Hu, Yong via Tech-talk
Prev: RE: Exploring EPICS performance/processing limits Mark Rivers via Tech-talk
Next: Re: mbbo & calcout for drive position management Crisp, Daniel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: Exploring EPICS performance/processing limits Ralph Lange via Tech-talk
