1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Exploring EPICS performance/processing limits
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "Hu, Yong" <[email protected]>
Date: Thu, 6 Oct 2022 18:44:27 +0000
Hi, Mark! As always, thanks for the help.
Where i before only had drvAsynIPPortConfigure("IPPORT1", "127.0.0.1:60000", 0, 0, 0), now i have:
asynSetTraceIOMask("IPPORT1", 0, ESCAPE)
asynSetTraceMask("IPPORT1", 0, ERROR|DRIVER)
and running the script again with the monitors both via camonitor and via tcpflow generate the following results:
FOR 5 SECONDS OF DELAY:
TCPFLOW RESULTS:
127.000.000.001.55866-127.000.000.001.60000: {"id":"1", "method":"HS_ImgChipNumberID_Command", "params": [["1", "0"]], "jsonrpc": "2.0"}
127.000.000.001.55866-127.000.000.001.60000: {"id":"1", "method":"HS_ImgChipNumberID_Command", "params": [["0"]], "jsonrpc": "2.0"}
127.000.000.001.55866-127.000.000.001.60000: {"id":"1", "method":"HS_ImgChipNumberID_Command", "params": [["1", "1"]], "jsonrpc": "2.0"}
127.000.000.001.55866-127.000.000.001.60000: {"id":"1", "method":"HS_ImgChipNumberID_Command", "params": [["1", "2"]], "jsonrpc": "2.0"}
127.000.000.001.55866-127.000.000.001.60000: {"id":"1", "method":"HS_ImgChipNumberID_Command", "params": [["1", "3"]], "jsonrpc": "2.0"}
CAMONITOR:
camonitor MOBICDTE:Backend:ImgChipNumberID
MOBICDTE:Backend:ImgChipNumberID <undefined> 0 UDF INVALID
CA.Client.Exception...............................................
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "MOBICDTE:Backend:ImgChipNumberID", Connecting to: 192.168.55.1:5064, Ignored: s-mgn-mob01-l.abtlus.org.br:5064"
    Source File: ../cac.cpp line 1320
    Current Time: Thu Oct 06 2022 15:36:31.762020681
MOBICDTE:Backend:ImgChipNumberID 2022-10-06 15:36:55.282127 0 READ INVALID
MOBICDTE:Backend:ImgChipNumberID 2022-10-06 15:37:00.287686 1 READ INVALID
MOBICDTE:Backend:ImgChipNumberID 2022-10-06 15:37:05.291961 2 READ INVALID
MOBICDTE:Backend:ImgChipNumberID 2022-10-06 15:37:10.296531 3 READ INVALID
IN THE IOC SHELL:
2022/10/06 15:36:55.180 127.0.0.1:60000 write 92
{\"id\":\"1\", \"method\":\"HS_ImgChipNumberID_Command\", \"params\": [[\"1\", \"0\"]], \"jsonr
2022/10/06 15:36:55.182 127.0.0.1:60000 read 57
{\"id\":\"1\", \"result\":\"Selected sensor 0\", \"jsonrpc\":\"2.0\"}
2022/10/06 15:36:55.283 127.0.0.1:60000 write 87
{\"id\":\"1\", \"method\":\"HS_ImgChipNumberID_Command\", \"params\": [[\"0\"]], \"jsonrpc\":
2022/10/06 15:36:55.284 127.0.0.1:60000 read 41
{\"id\":\"1\", \"result\":\"0\", \"jsonrpc\":\"2.0\"}
2022/10/06 15:37:00.185 127.0.0.1:60000 write 92
{\"id\":\"1\", \"method\":\"HS_ImgChipNumberID_Command\", \"params\": [[\"1\", \"1\"]], \"jsonr
2022/10/06 15:37:00.187 127.0.0.1:60000 read 57
{\"id\":\"1\", \"result\":\"Selected sensor 1\", \"jsonrpc\":\"2.0\"}
2022/10/06 15:37:00.289 127.0.0.1:60000 write 87
2022/10/06 15:37:00.289 127.0.0.1:60000 read 41
{\"id\":\"1\", \"result\":\"1\", \"jsonrpc\":\"2.0\"}
2022/10/06 15:37:05.190 127.0.0.1:60000 write 92
{\"id\":\"1\", \"method\":\"HS_ImgChipNumberID_Command\", \"params\": [[\"1\", \"2\"]], \"jsonr
2022/10/06 15:37:05.191 127.0.0.1:60000 read 57
{\"id\":\"1\", \"result\":\"Selected sensor 2\", \"jsonrpc\":\"2.0\"}
2022/10/06 15:37:05.293 127.0.0.1:60000 write 87
2022/10/06 15:37:05.294 127.0.0.1:60000 read 41
{\"id\":\"1\", \"result\":\"2\", \"jsonrpc\":\"2.0\"}
2022/10/06 15:37:10.194 127.0.0.1:60000 write 92
{\"id\":\"1\", \"method\":\"HS_ImgChipNumberID_Command\", \"params\": [[\"1\", \"3\"]], \"jsonr
2022/10/06 15:37:10.196 127.0.0.1:60000 read 57
{\"id\":\"1\", \"result\":\"Selected sensor 3\", \"jsonrpc\":\"2.0\"}
2022/10/06 15:37:10.298 127.0.0.1:60000 write 87
2022/10/06 15:37:10.298 127.0.0.1:60000 read 41
{\"id\":\"1\", \"result\":\"3\", \"jsonrpc\":\"2.0\"}
WITH 0.1 SECOND OF DELAY:
TCPFLOW:
CAMONITOR:
MOBICDTE:Backend:ImgChipNumberID 2022-10-06 15:40:05.170536 1 READ INVALID
MOBICDTE:Backend:ImgChipNumberID 2022-10-06 15:40:05.376049 3 READ INVALID
IOCSHELL:
2022/10/06 15:40:05.070 127.0.0.1:60000 read 57
2022/10/06 15:40:05.172 127.0.0.1:60000 write 87
2022/10/06 15:40:05.172 127.0.0.1:60000 read 41
2022/10/06 15:40:05.274 127.0.0.1:60000 write 92
2022/10/06 15:40:05.275 127.0.0.1:60000 read 57
2022/10/06 15:40:05.377 127.0.0.1:60000 write 87
2022/10/06 15:40:05.378 127.0.0.1:60000 read 41
2022/10/06 15:40:05.480 127.0.0.1:60000 write 92
2022/10/06 15:40:05.481 127.0.0.1:60000 read 57
2022/10/06 15:40:05.583 127.0.0.1:60000 write 87
2022/10/06 15:40:05.583 127.0.0.1:60000 read 41
So i think the IOC is actually having trouble with sending the commands? This is bizarre to me, i have used streamdevice before with higher speeds and never have any trouble of this kind at all.
Sent: 06 October 2022 11:16
To: Hu, Yong <[email protected]>; Marco A. Barra Montevechi Filho <[email protected]>
Cc: [email protected] <[email protected]>
Subject: RE: Exploring EPICS performance/processing limits
Ø  To me, looping with “caput_one_pv_at_a_time” seems inefficient, especially in the Python world where “list” is a daily-usable data structure.
That may be true, but it does not really address the issue Marco is reporting, which is unexpectedly poor behavior with single caput operations.
Marco, since you are using streamDevice in your IOC and the loopback IP address that means you must have created an drvAsynIPPort port for the communication.  The first line of debugging you should use is to enable asynTraceIODriver on that port.  That will show you exactly what is being sent on the network without needing to run tcpinfo.  In your IOC st.cmd add these lines:
asynSetTraceIOMask(portName, 0, ESCAPE)
asynSetTraceMask(portName, 0, ERROR|DRIVER)
where portName is the name you gave to the drvAsynIPPort.
This will show the communication over that socket.  See if it agrees with what tcpinfo shows.
From: Tech-talk <[email protected]> On Behalf Of Hu, Yong via Tech-talk
Sent: Thursday, October 6, 2022 8:33 AM
To: Marco A. Barra Montevechi Filho <[email protected]>; [email protected]
Hello Marco,
I have been using another Python-based Channel Access tool named “cothread” where you simply caput a list of pvs associated with a list of values: cothread.catools.caput(pvs, values). In your case, cothread.catools.caput(a_list_of_records, VALUE, repeat_value=True).
I have used “cothread” in one application where I get ~200 BPM waveform data (100K doubles per BPM) in a few seconds by caget(bpm_wavform_pv_list). Basically the processing time is dominated by the limited network bandwidth. “cothread” is very efficient by using cooperative threading.
Take a look at these links:
https://github.com/dls-controls/cothread
https://cothread.readthedocs.io/en/latest/catools.html#cothread.catools.caput
Cheers,
Yong
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Date: Wednesday, October 5, 2022 at 7:26 PM
To: [email protected] <[email protected]>
Subject: Exploring EPICS performance/processing limits
Hello all.
I bumped into something that may or may not be caused by EPICS default processing time limits and would like tips on how to explore it, if possible.
I have a set of records that send messages to a loopback ethernet address via a .proto file and stream device.
Lets say RECORD1 sends a string "message1 VAL1", RECORD2 sends "message2 VAL2", etc.
I was monitoring the traffic with ´tcpflow -c -i <my_IP> port <my_PORT> | grep "message"´ and made a python script in the form:
import epics, time
def do_thing(x):
    for record in ["RECORD1", "RECORD2", "RECORD3", "RECORD4"]:
        epics.caput(record, VALUE)
        time.sleep(x)
The messages i got from tcpflow when executing the python script with do_thing(1.5) were nicely formatted:
message1 VALUE
message2 VALUE
message3 VALUE
message4 VALUE
But when i do the same thing with x=0.5, messages 2 and 3 were sometimes missing or sometimes badly formatted. Sometimes i got things like:
message1 VALUE
message2
message3
message4 VALUE
And sometimes like:
message1 VALUE
message4 VALUE
Is this a PV processing time issue? Shouldnt the IOC be capable of dealing with time intervals smaller than this? Is there a way i can improve this behaviour without setting sleep times between my caputs?
Thanks in advance,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
RE: Exploring EPICS performance/processing limits Mark Rivers via Tech-talk
Exploring EPICS performance/processing limits Marco A. Barra Montevechi Filho via Tech-talk
Re: Exploring EPICS performance/processing limits Hu, Yong via Tech-talk
Prev: Re: mbbo & calcout for drive position management Crisp, Daniel via Tech-talk
Next: Re: asynMotorController weird behavior when using any read/write interface mask Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: Exploring EPICS performance/processing limits Mark Rivers via Tech-talk
Next: RE: Exploring EPICS performance/processing limits Mark Rivers via Tech-talk
