1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: modbus-tcp
Date: Tue, 11 Oct 2022 10:46:50 +0800
I am trying to control a device which can get the temperature values ,I used modbus_tk under python to get the value. In order to match with EPICS, I used the support module PyDevice which is an EPICS device support for Python interpreter, When I run the st.cmd file,the complete output when the IOC boots as follows:
 ./st.cmd
#!../../bin/linux-x86_64/waveioc
< envPaths
epicsEnvSet("IOC","waveioc")
epicsEnvSet("TOP","/home/iocusr/iocs/WAVEIOC")
epicsEnvSet("MODULES","/opt/epics/base/../modules")
epicsEnvSet("AUTOSAVE","/opt/epics/base/../modules/autosave-R5-7-1")
epicsEnvSet("ASYN","/opt/epics/base/../modules/asyn-R4-41")
epicsEnvSet("BUSY","/opt/epics/base/../modules/busy-1-6-1")
epicsEnvSet("CALC","/opt/epics/base/../modules/calc-R3-7-4")
epicsEnvSet("CAPUTLOG","/opt/epics/base/../modules/caPutLog-3-5")
epicsEnvSet("IOCSTATS","/opt/epics/base/../modules/iocStats-3-1-16")
epicsEnvSet("MODBUS","/opt/epics/base/../modules/modbus-R3-2")
epicsEnvSet("NETDEV","/opt/epics/base/../modules/netDev-1-0-6")
epicsEnvSet("PC-MONITOR","/opt/epics/base/../modules/PC-MONITOR1-0-2")
epicsEnvSet("PROCSERVCONTROL","/opt/epics/base/../modules/procServControl-1-9")
epicsEnvSet("S7NODAVE","/opt/epics/base/../modules/s7nodave-2-1-3")
epicsEnvSet("S7PLC","/opt/epics/base/../modules/s7plc")
epicsEnvSet("SSCAN","/opt/epics/base/../modules/sscan-2-10")
epicsEnvSet("STREAM","/opt/epics/base/../modules/StreamDevice-2-8-9")
epicsEnvSet("SNCSEQ","/opt/epics/base/../modules/seq-2-2-6")
epicsEnvSet("PYDEVICE","/opt/PyDevice")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("EPICS_CA_SERVER_PORT", 5064))
epicsEnvSet("IOCNAME","waveioc")
cd "/home/iocusr/iocs/WAVEIOC"
dbLoadDatabase "dbd/waveioc.dbd"
waveioc_registerRecordDeviceDriver pdbbase
Executing Python code: import pydev
Executing Python code: import builtins
Executing Python code: builtins.pydev=pydev
pydev("import sys; sys.path.insert(0,'/home/iocusr/iocs/WAVEIOC/iocBoot/waveioc')")
Executing Python code: import sys; sys.path.insert(0,'/home/iocusr/iocs/WAVEIOC/iocBoot/waveioc')
pydev("import modbus_tk")
Executing Python code: import modbus_tk
pydev("from wave import Temp")
Executing Python code: from wave import Temp
pydev("temp1 = Temp('192.168.0.11','502')")
Executing Python code: temp1 = Temp('192.168.0.11','502')
dbLoadRecords "db/dbWaveform.db", "user=waveioc"
# Configure IP port
# drvAsynIPPortConfigure("CAT1","10.40.15.9:502",0,0,1)
# Configure modbus
# modbusInterposeConfig("CAT1",ModbusLinkType,timeoutMsec,writeDelayMsec)
# drvModbusAsynConfigure("WORDIR","CAT1",slaveAddress,modbusFunction,modbusStartAddr,modbusLen,dataType,posMsec,"plcType")
cd "/home/iocusr/iocs/WAVEIOC/iocBoot/waveioc"
iocInit
Starting iocInit
## EPICS R7.0.5
## Rev. 2021-08-27T15:52+0800
sevr=info s7plcInit: no stations configured
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
# List all PVs to PV information files.
#dbl >> ${PVINFOFILE}
epics> [31.1  0.   0.  ... 21.2  0.   0. ]
db[31.1  0.   0.  ... 21.2  0.   0. ]
l
waveioc:TEMP
waveioc:RISE
waveioc:PEAK
waveioc:GETDATA
​        epics> [31.   0.   0.  ... 21.4  0.1  0. ]
​Is there any way to prevent the epics terminal from automatically displaying the values obtained?
Re: modbus-tcp Simon Rose via Tech-talk
Prev: Re: Phoebus zoom etc toolbar Kasemir, Kay via Tech-talk
Next: modbus-tcp liuxiaomin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: mbbi excessive archiving William F Badgett Jr via Tech-talk
Next: Re: modbus-tcp Simon Rose via Tech-talk
