1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: modbus-tcp
To: liuxiaomin <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 11 Oct 2022 06:46:38 +0000
Can you send a link to your code (python and otherwise)? It might be helpful to see that…
Cheers,
Simon
______________________
Simon Rose
Software Engineer
Control System Software and Services
European Spallation Source ERIC
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
Mobile: +46 72 179 23 07
E-mail: [email protected]
signature_2468140004
From: Tech-talk <[email protected]> on behalf of liuxiaomin via Tech-talk <[email protected]>
Reply to: liuxiaomin <[email protected]>
Date: Tuesday, 11 October 2022 at 04:47
Subject: modbus-tcp
I am trying to control a device which can get the temperature values ,I used modbus_tk under python to get the value. In order to match with EPICS, I used the support module PyDevice which is an EPICS device support for Python interpreter, When I run the st.cmd file,the complete output when the IOC boots as follows:
 ./st.cmd
#!../../bin/linux-x86_64/waveioc
< envPaths
epicsEnvSet("IOC","waveioc")
epicsEnvSet("TOP","/home/iocusr/iocs/WAVEIOC")
epicsEnvSet("MODULES","/opt/epics/base/../modules")
epicsEnvSet("AUTOSAVE","/opt/epics/base/../modules/autosave-R5-7-1")
epicsEnvSet("ASYN","/opt/epics/base/../modules/asyn-R4-41")
epicsEnvSet("BUSY","/opt/epics/base/../modules/busy-1-6-1")
epicsEnvSet("CALC","/opt/epics/base/../modules/calc-R3-7-4")
epicsEnvSet("CAPUTLOG","/opt/epics/base/../modules/caPutLog-3-5")
epicsEnvSet("IOCSTATS","/opt/epics/base/../modules/iocStats-3-1-16")
epicsEnvSet("MODBUS","/opt/epics/base/../modules/modbus-R3-2")
epicsEnvSet("NETDEV","/opt/epics/base/../modules/netDev-1-0-6")
epicsEnvSet("PC-MONITOR","/opt/epics/base/../modules/PC-MONITOR1-0-2")
epicsEnvSet("PROCSERVCONTROL","/opt/epics/base/../modules/procServControl-1-9")
epicsEnvSet("S7NODAVE","/opt/epics/base/../modules/s7nodave-2-1-3")
epicsEnvSet("S7PLC","/opt/epics/base/../modules/s7plc")
epicsEnvSet("SSCAN","/opt/epics/base/../modules/sscan-2-10")
epicsEnvSet("STREAM","/opt/epics/base/../modules/StreamDevice-2-8-9")
epicsEnvSet("SNCSEQ","/opt/epics/base/../modules/seq-2-2-6")
epicsEnvSet("PYDEVICE","/opt/PyDevice")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("EPICS_CA_SERVER_PORT", 5064))
epicsEnvSet("IOCNAME","waveioc")
cd "/home/iocusr/iocs/WAVEIOC"
dbLoadDatabase "dbd/waveioc.dbd"
waveioc_registerRecordDeviceDriver pdbbase
Executing Python code: import pydev
Executing Python code: import builtins
Executing Python code: builtins.pydev=pydev
pydev("import sys; sys.path.insert(0,'/home/iocusr/iocs/WAVEIOC/iocBoot/waveioc')")
Executing Python code: import sys; sys.path.insert(0,'/home/iocusr/iocs/WAVEIOC/iocBoot/waveioc')
pydev("import modbus_tk")
Executing Python code: import modbus_tk
pydev("from wave import Temp")
Executing Python code: from wave import Temp
pydev("temp1 = Temp('192.168.0.11','502')")
Executing Python code: temp1 = Temp('192.168.0.11','502')
dbLoadRecords "db/dbWaveform.db", "user=waveioc"
# Configure IP port
# drvAsynIPPortConfigure("CAT1","10.40.15.9:502",0,0,1)
# Configure modbus
# modbusInterposeConfig("CAT1",ModbusLinkType,timeoutMsec,writeDelayMsec)
# drvModbusAsynConfigure("WORDIR","CAT1",slaveAddress,modbusFunction,modbusStartAddr,modbusLen,dataType,posMsec,"plcType")
cd "/home/iocusr/iocs/WAVEIOC/iocBoot/waveioc"
iocInit
Starting iocInit
## EPICS R7.0.5
## Rev. 2021-08-27T15:52+0800
sevr=info s7plcInit: no stations configured
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults to "."
# List all PVs to PV information files.
#dbl >> ${PVINFOFILE}
epics> [31.1  0.   0.  ... 21.2  0.   0. ]
db[31.1  0.   0.  ... 21.2  0.   0. ]
l
waveioc:TEMP
waveioc:RISE
waveioc:PEAK
waveioc:GETDATA
​        epics> [31.   0.   0.  ... 21.4  0.1  0. ]
​Is there any way to prevent the epics terminal from automatically displaying the values obtained?
modbus-tcp liuxiaomin via Tech-talk
Prev: modbus-tcp liuxiaomin via Tech-talk
Next: Re: [EXTERNAL] PVXS and Phoebus Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: modbus-tcp liuxiaomin via Tech-talk
