1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Question about extracting information from a bo type record in EPICS
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 20 Oct 2022 17:50:35 +0200
Well,
Actually, the snippet you provided does not contain the ca_get() call.
You create the channel with ca_create_channel() and you wait for a result with ca_pend_io() - but you don't issue a CA command.
One of the examples in Base (that can be created with the makeBaseApp script) is a simple channel access client. That minimal code snippet should give you an idea of how to work with the CA client library.
And there's of course the documentation: https://epics.anl.gov/base/R7-0/7-docs/CAref.html#ca_get
Cheers,
~Ralph
Question about extracting information from a bo type record in EPICS Meddage, Varuna via Tech-talk
Re: Question about extracting information from a bo type record in EPICS Mark Rivers via Tech-talk
Re: Question about extracting information from a bo type record in EPICS Meddage, Varuna via Tech-talk
Prev: Re: starting ImageJ/EPICS_AD_Viewer with specified PVPrefix Mark Rivers via Tech-talk
Next: Re: starting ImageJ/EPICS_AD_Viewer with specified PVPrefix Wlodek, Jakub via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Question about extracting information from a bo type record in EPICS Mark Rivers via Tech-talk
Next: starting ImageJ/EPICS_AD_Viewer with specified PVPrefix John Dobbins via Tech-talk
