1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: IOC make failing on a new linux build, Perl checkrelease
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 25 Oct 2022 06:12:09 +0000
Took one of our IOCs and tried to run make on a new build, getting EPICS_BASE needs to be defined in release file but it is.  This ioc will build on all of other linux machines but for some reason not this one.
Checked the release file and it’s defined, double checked to make sure HOME was echoing correctly in command prompt.  Made sure that the path CDs into the directory as well.
EPICS_BASE=${HOME}/epics/base
If I write out the full path seems to compile fine but for some reason the env variable home is not making it into the release file.  Feel like I am missing something obvious when we set up our other machines vs this new build.
Thanks
Re: IOC make failing on a new linux build, Perl checkrelease Han Lee via Tech-talk
Re: IOC make failing on a new linux build, Perl checkrelease Andrew Johnson via Tech-talk
Prev: Re: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: IOC make failing on a new linux build, Perl checkrelease Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Phoebus Alarm Server - Alarm acknowledgement from EPICS record Kasemir, Kay via Tech-talk
