Please try to use the following trick, and you will see the EPICS IOC can compile your IOC.
echo "CHECK_RELEASE=NO" > configure/CONFIG_SITE.local
However, I recommend using an absolute path of EPICS BASE.
Best, Han
P.S. CONFIG file and convertRelease.pl have an `EPICS_BASE` checker in different scenarios. You can go ahead and check them.
On Mon, Oct 24, 2022 at 11:12 PM Manoussakis, Adamandios via Tech-talk < [email protected]> wrote: Took one of our IOCs and tried to run make on a new build, getting EPICS_BASE needs to be defined in release file but it is. This ioc will build on all of other linux machines but for some reason not this one.
Checked the release file and it’s defined, double checked to make sure HOME was echoing correctly in command prompt. Made sure that the path CDs into the directory as well.
EPICS_BASE=${HOME}/epics/base
If I write out the full path seems to compile fine but for some reason the env variable home is not making it into the release file. Feel like I am missing something obvious when we set up our other machines vs this new build.
Thanks
Jeong Han Lee, Dr.rer.nat Staff Scientist and Engineer Lawrence Berkeley National Laboratory 1 Cyclotron Road Mailstop 46R0161 Berkeley, CA 94720, United States Tel :+1-510-486-6163
Cell:+1-510-384-3868
- IOC make failing on a new linux build, Perl checkrelease Manoussakis, Adamandios via Tech-talk
Re: IOC make failing on a new linux build, Perl checkrelease Andrew Johnson via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
