1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Grabbing data from REST API
From: Sean Leavey via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 28 Oct 2022 14:16:15 +0100
Hi Mark,
I had hoped to avoid implementing REST client code myself! It'd be cool if there were a module that could map REST API endpoints (and probably some template for extracting the value from the returned HTTP body) to records.
I think if implementing my own client ends up being the only way (short of writing a REST client module described above - I'm not ready to tackle that yet), I'd rather use this driver that I alluded to in my first email and implement the client code in Python: https://github.com/paulscherrerinstitute/asynPythonDriver
Cheers,
Sean
On 28/10/2022 13:46, Mark Rivers wrote:
Hi Sean,
The Eiger detectors from Dectris use the REST API.  This is the code that is used to communicate with them from EPICS.
https://github.com/areaDetector/ADEiger/blob/master/eigerApp/src/restApi.cpp <https://github.com/areaDetector/ADEiger/blob/master/eigerApp/src/restApi.cpp>
*From:* Tech-talk <[email protected]> on behalf of Sean Leavey via Tech-talk <[email protected]>
*Sent:* Friday, October 28, 2022 7:22 AM
*To:* [email protected] <[email protected]>
*Subject:* Grabbing data from REST API
Hi all,
I've got a sensor that provides its measurements via a REST API. I saw
on the mailing list in 2017
(https://epics.anl.gov/tech-talk/2017/msg01698.php <https://epics.anl.gov/tech-talk/2017/msg01698.php>) there was a message
about writing a generic REST client module for EPICS and wondered if
anything came about from this. If not, does anyone have a suggestion how
to talk REST via EPICS? I remember seeing a module that allowed the IOC
to call out to a Python script, where I could implement the REST part,
but I wondered if there's something a bit more focused on this
particular task available already as an EPICS module.
Cheers,
Sean
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
RE: [EXTERNAL] Re: Grabbing data from REST API Pearson, Matthew via Tech-talk
Grabbing data from REST API Sean Leavey via Tech-talk
Re: Grabbing data from REST API Mark Rivers via Tech-talk
Prev: Re: Grabbing data from REST API Mark Rivers via Tech-talk
Next: Re: Missing DLL entry points in PV utils on windows-x64-mingw? Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: RE: [EXTERNAL] Re: Grabbing data from REST API Pearson, Matthew via Tech-talk
