1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error
From: Amit Chauhan via Tech-talk <[email protected]>
To: whitetiger1123 <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 10 Nov 2022 13:48:19 +0530
Try writing only 'vxWorks' for the field 'File name:'  as below
File name : vxWorks
Amit
On 11/10/2022 11:51 AM, whitetiger1123 via Tech-talk wrote:
I really appreciate helping me and solve this problem
Now I know how to put a filename path, and it doesn’t show me weird word(like /???/test/vxworks???/) anymore
But I have some questions about configuration of MVME6100
My purpose is to booting vxWorks 6.9 on MVME6100
When I try to download(by tftp) vxWorks boot file from server to MVME6100, there is an error message for ‘Error loading file:errorno = 0x3c.’
So I research this error and it shows me this error means ETIMEDOUT.
I think this error is because of server (that has the vxWorks boot file) can’t run tftp. Is my guess right?
But I install tftp on the server very well and I tested this tftp on this server as well.
I don’t know what problem is.
Is anyone check my error and environment s what problem is?
My error and environments are below:
1.    Hardware : MVME6100
2.    Software : Ubuntu 9.04 (this server has vxWorks Image setup file)
1.    MVME6100 setting
Switch(s4) position 4,2,1 OFF / 4 ON
2.    Booting log on MVME6100 by vxWorks kernel
[Vxworks Boot]:@
Boot device              : geisc0
Unit number           : 0
Processor number : 0
Host name               : host
File name                 : /work/vxconfig/vxworks/default/vxWorks
Inet on ethernet    : 10.4.49.67:ffffff00
Host inet                   :10.4.49.170
Gateway inet           :10.4.49.99
User                            :test
ftp password           :test
flags                           :0x0
                  Attached TCP/IP interfce to geisc0.
                  Attaching network interface lo0… done.
                  Loading..
                  Error loading file : errno = 0x3c.
vxWorks boot file path is /home/test/work/vxconfig/vxworks/default/vxWorks.
Do I have to use file path host:/work/vxconfig/vxworks/default/vxWorks or /home/test/work/vxconfig/vxworks/default/vxWorks like this? (←but it shows me a same error 0x3c.)
I really want to know how to solve this error
And always appreciate to reply my message and help me how to solve lots of error.
Thanks!
Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Ralph Lange via Tech-talk
vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error whitetiger1123 via Tech-talk
Prev: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error whitetiger1123 via Tech-talk
Next: Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
