Subject: |
Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error |
Ralph Lange via Tech-talk <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Thu, 10 Nov 2022 09:43:09 +0100 |
Try writing only 'vxWorks' for the field 'File name:' as below
File name : vxWorks
Background: The file name is usually relative to the root of the download area of the tftp server (probably set as TFTP_DIRECTORY in the server configuration). On the server, the file should really be located below that directory (soft links on the server pointing outside the tftp area won't work).
Cheers, ~Ralph
- Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Johnson, Andrew N. via Tech-talk
- vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error whitetiger1123 via Tech-talk
- Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Amit Chauhan via Tech-talk
Altering motor resolution via MRES field Marco A. Barra Montevechi Filho via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
