1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: asynPortDriver nDevices?
To: Heinz Junkes <[email protected]>
Date: Fri, 11 Nov 2022 16:25:36 +0000
Hi Heinz,
> I have a VMEbus system with 4 Highland arbitrary waveform generators ( 1x V346, 3 x V344).
> Each of these cards holds 8 channels.
> Therefore I call asynPortDriver with 4 (nCards) * 8 (NUM_CHANNELS) (= 32) addresses:
> I'm just confused that with the asynReport I always get displayed "8"  as nDevices:
When you pass nrCards * NUM_CHANNELS to the asynPortDriver constructor you are telling it how many parameter lists to create, 32 in this case.  That value is not passed to asynManager, which only knows that the driver is ASYN_MULTIDEVICE.  asynManager dynamically creates the "devices" based on the value of the "addr" field in the link field.  If there are only 8 then your database must have only used "addr"=0-7.
The question of how best to configure your driver depends on how it needs to function.  Normally I would say that you would create 4 asynPortDriver instances, one for each card, and each with 8 addresses.  You definitely would want to do this if the cards are to act independently, or if you might sometimes use a different number of cards.
On the other hand, if your 4 cards are tightly coupled, and all parameters will be identical on channel N of each card, then what you have done, creating a single asynPortDriver might make sense.  Note that there are only 8 parameters lists being used in your driver currently.  That means that each parameter, for example time per waveform point, will be the same on all 4 cards because there are not separate parameter lists for each card.  You could force different parameter lists for each card by changing the "addr" field in your database so it ranges from 0 to 31 rather than 0 to 8.  So addr=card*8 + channel.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Heinz Junkes via Tech-talk
Sent: Friday, November 11, 2022 10:07 AM
To: EPICS Tech Talk <[email protected]>
Subject: asynPortDriver nDevices?
I am a little confused about the use of asynPortDriver().
AwgPort::AwgPort(const char *portName, epicsUInt16 a, epicsUInt16 nrCards)
    :asynPortDriver(portName, nrCards * NUM_CHANNELS,// NUM_PARAMS,
            asynInt32Mask | asynInt16ArrayMask | asynInt32ArrayMask | asynFloat64Mask | asynFloat64ArrayMask | asynOctetMask | asynDrvUserMask,
            asynInt32Mask | asynInt16ArrayMask | asynInt32ArrayMask | asynFloat64Mask | asynFloat64ArrayMask,
                    ASYN_MULTIDEVICE,
                    1, // autoconnect
                    0, // prio
                    0)
"Somehow" everything looks good too.
tIocSh> asynReport 1,awgport
awgport multiDevice:Yes canBlock:No autoConnect:Yes
    enabled:Yes connected:Yes numberConnects 1
    nDevices 8 nQueued 0 blocked:No
    asynManagerLock:No synchronousLock:No
    exceptionActive:No exceptionUsers 1 exceptionNotifys 0
    traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
    addr 0 autoConnect Yes enabled Yes connected Yes exceptionActive No
        exceptionActive No exceptionUsers 0 exceptionNotifys 0
        blocked No
    addr 1 autoConnect Yes enabled Yes connected No exceptionActive No
        blocked No
    addr 2 autoConnect Yes enabled Yes connected No exceptionActive No
        blocked No
    addr 3 autoConnect Yes enabled Yes connected No exceptionActive No
        blocked No
    addr 4 autoConnect Yes enabled Yes connected No exceptionActive No
        blocked No
    addr 5 autoConnect Yes enabled Yes connected No exceptionActive No
        blocked No
    addr 6 autoConnect Yes enabled Yes connected No exceptionActive No
        blocked No
    addr 7 autoConnect Yes enabled Yes connected No exceptionActive No
        blocked No
Port: awgport
Danke Heinz
asynPortDriver nDevices? Heinz Junkes via Tech-talk
Prev: asynPortDriver nDevices? Heinz Junkes via Tech-talk
Next: Linear regression record support Peregrine McGehee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
